Results 1 to 10 of 19
- Sep 2013
- 56
August 2nd, 2018 11:54 AM #1Guys I just wanna share a little DIY I just did. O overfilled my engine oil by about 300 ml and O didnt want to drain it via the drain plug in the oil pan and refill the oil. What I did was buy the biggest syringe i could find in the drug store, attach it to a clear plastic aquarium hose then inserted it into the oil dipstick hole then suck the oil with the syringe. Repeated process until O rwmived the rigjt ammount of oil. Easy, no need to crawl under your car!
Sent from my SM-N920S using Tapatalk
- Feb 2014
- 2,696
August 2nd, 2018 12:24 PM #2yeah i've done that.
for cleanup just feed some degreaser + water through the syringe and hose. then lube the syringe rubber w/ some silicone grease
August 2nd, 2018 03:09 PM #4
Good tip. Should work equally well with ATF.
Just remember to use a hose that's long enough to prevent you from accidentally dropping it inside the crankcase. :D
- Feb 2014
- 2,696
August 2nd, 2018 03:09 PM #5this is just for sucking out excess oil maybe 150cc
coz the idiots at the casa always overfill. you're supposed to measure via dipstick after resting the engine for about 5mins. but no they kill the engine then measure immediately. of course it'll read low so they add more oil
- Sep 2013
- 56
August 2nd, 2018 10:51 PM #6I wanted to post a picture it but I cNt seem to upload pics here
- Jan 2008
- 4,726
August 2nd, 2018 10:56 PM #7
- Feb 2014
- 2,696
August 2nd, 2018 11:03 PM #8
August 2nd, 2018 11:13 PM #9
- 54,211
^ I saw those "fire stop" 1 liter flame suppressants nga, but I decided to get the dry chem abc...
Fire Extinguisher for Car: what brand and type...
