Results 1 to 9 of 9
- Feb 2007
- 60
October 5th, 2007 08:13 PM #1Guys, help naman po...
Okay lang ba DIY na lang fuel filter replacement? May I ask how it is done? My car is 90 corolla gl. Naka-carb. Tingin ko kasi it's supposed to be a simple procedure. Kaya lang mahirap mangahas at baka kung ano ang magalaw ko. Newbie pa rin lang kasi ako pagdating sa car maintenance. Thanks in advance.
October 5th, 2007 08:49 PM #2
loosen the filter mounts. loosen the clamps on both filter hose, pull out the hose on both ends. do the same with the new filter in reverse taking note of the in/out arrow configuration. there will be a little fuel spill so do this on a cold engine. do not smoke or work near flamable materials.
- Feb 2007
- 60
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 6th, 2007 05:48 PM #5Add ko lang, before doing any thing, remove your gas tank cover. This is to relive any pressure in your fuel system. And keep yur tools away from the battery.
- Feb 2007
- 60
October 6th, 2007 07:50 PM #6Thanks po... I did the replacement kanina and wala naman naging problem.
October 6th, 2007 11:35 PM #7
since we're on the fuel filter replacement subject. paano naman yung metal fuel fileter ng sa lancer pizza? is it as simple as the regular fuel filters of carb engines?
- Jun 2006
- 2,605
October 7th, 2007 08:12 AM #8Metal fuel filter, halos pareho lang sa reg plastic filter. Pero high pressure yan. So you have to relive the pressure 1st otherwise spray ang fuel. Locate and remove the fuse for your fuel pump to relieve the pressure. Before pulling the hoses, wrap them in rags to catch any spills.
Eto detailed instructons. http://autorepair.about.com/od/regul...uel_filter.htm
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 7th, 2007 10:10 AM #9actually you can relieve the pressure by opening the gas cap din.
harder for metal filters kasi you need tools pa. the size normally depends on the car.
