Results 1 to 9 of 9
    Feb 2007
    Guys, help naman po...
    Okay lang ba DIY na lang fuel filter replacement? May I ask how it is done? My car is 90 corolla gl. Naka-carb. Tingin ko kasi it's supposed to be a simple procedure. Kaya lang mahirap mangahas at baka kung ano ang magalaw ko. Newbie pa rin lang kasi ako pagdating sa car maintenance. Thanks in advance.
    loosen the filter mounts. loosen the clamps on both filter hose, pull out the hose on both ends. do the same with the new filter in reverse taking note of the in/out arrow configuration. there will be a little fuel spill so do this on a cold engine. do not smoke or work near flamable materials.
    Feb 2007
    thanks for the immediate reply mr afrasay... simple nga lang pala.
    safety first, remember you are working with a flamable liquid.
    Jun 2006
    Add ko lang, before doing any thing, remove your gas tank cover. This is to relive any pressure in your fuel system. And keep yur tools away from the battery.
    Feb 2007
    Thanks po... I did the replacement kanina and wala naman naging problem.
DIY ng fuel filter replacement
