Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 85
    #21
    the octane level of the fuel in your gas tank goes down. the worse that can happen is you rev the engine and it knocks. or there is more diesel than gasoline so the engine does not run at all.
    first thing i'd do is to fill up to full tank to dilute that diesel. 2nd, add octane enhancer and stay in low revs (below 3k) until the next full tank.
    or drain the tank tutal sabi mo 1/4 level na lang.
    Jan 2017
    #22
    As of right now no issues so far as to pagkakaiba ng takbo from before. Sguro 15km ride na. Or mmya kopa mraramdaman effect nya? Or sa sobrang pagka pagod ko kahapon hnd nmn tlga diesel kinarga saken
    Oct 2009
    #23
    may oner type jeep ako dati RF mazda makina diesel.nakargahan din sa shell ng macapagal ng gasoline.wala pang 3 mins pumalya agad makina at parang nag wa wild..nung nakita ko resibo gasoline ung nilagay..pero may naka indicate ako dun sa bukasan ng tanke na diesel..sabi nung gasoline boy bihira daw kasi ung diesel sa oner type jeep ayun..tinanggal lahat ng laman at pinalitan nila kung gano karami ung laman ng tangke ganun din ung ipinalit..
    Jul 2012
    #24
    Kung naging mas mausok na kulay puti ang buga ng tambutso mo kaysa dati then may diesel nga nahalo sa fuel mo.
    Jan 2017
    #25
    Quote Originally Posted by GerryT247 View Post
    Pano ko manonotice un? Habang nka park i rev ko ung engine?
    Quote Originally Posted by jaypee10 View Post
    Kaso sakin konti lng kya bka mamaya pa papalya. Pde bng ganung logic or bsta may diesel palya na dpat agad?
    Jul 2013
    #26
    Putting Petrol Into A Diesel Car #TBT - Fifth Gear - YouTube
    Sent from Zenfone 3 on Tsikot mobile app
    Feb 2012
    #27
    Quote Originally Posted by Kimchijiji View Post
    So kahapon gabi sobrang tired kona at nagpa gas ako sa shell ng unleaded worth 200. When i was about to pay, nakta ko ibang pump nozzle binalik yung kulay itim which is shell fuelsave diesel instead of the green na fuelsave unleaded. Ang tanong ko is bka naghaluccinate lng ako kagabi sa sobrang pagod kya akalain ko diesel nilagay. As of now hnd nmn nag stutter ung engine still runs fine bka kasi konti lng pina gas kong diesel or dapat ma notice ko agad difference? And magkakasya ba nozzle ng diesel sa gas engine? Ang alam ko mas malaki daw ung diesel kya kng ganun hnd magkakasya sakin un.
    Baka namalik mata kalang TS, naramdaman muna dapat yan sa tinakbo mo. Happens to us long time ago sa petron naman, oner naman gas engine 4k kinargahan ng diesel. Mga 2kilometers palang tinakbo tumirik na eh,good thing mag malapit ma talyer kung saan tumirik. Pag open nila ng carburador amoy diesel, balik kami sa petron ayun deny to the bones ang gasoline boy which we forgot to take the receipt.haha
    Drain lang ung tank ng oner and lininis ung line and carb and changed spark plug.
    Jan 2017
    #28
    Quote Originally Posted by erdiedizon View Post
    Kahit mga 4-5 liters na diesel lng kinarga ko?
    #29
    How did you confirm that you loaded diesel? If it's just because of the nozzle jacket, it's actually highly likely that they just mistakenly put a black jacket on a gasoline nozzle.
    Gas and diesel nozzles are exactly the same, but if you're driving a sedan I don't think you'll get a misfill.
    Most common misfill vehicles are Innovas, Tucsons, and Fortuners because all of them are offered in both gas and diesel variants.
    #30
    BALIKTAD ANG CASE NI TS. sa iyo diesel engine na nakargahan ng gasoline. sa kanya gasoline engine na nakargahan ng diesel. iba ang consequence nun. yours is a compression ignition.engine. his is a spark ignition engine.
Diesel loaded in a gas engine
