Results 21 to 30 of 85
August 20th, 2017 06:06 PM #21
the octane level of the fuel in your gas tank goes down. the worse that can happen is you rev the engine and it knocks. or there is more diesel than gasoline so the engine does not run at all.
first thing i'd do is to fill up to full tank to dilute that diesel. 2nd, add octane enhancer and stay in low revs (below 3k) until the next full tank.
or drain the tank tutal sabi mo 1/4 level na lang.
- Jan 2017
- 429
August 20th, 2017 06:26 PM #22
- Oct 2009
- 2,271
August 20th, 2017 07:04 PM #23may oner type jeep ako dati RF mazda makina diesel.nakargahan din sa shell ng macapagal ng gasoline.wala pang 3 mins pumalya agad makina at parang nag wa wild..nung nakita ko resibo gasoline ung nilagay..pero may naka indicate ako dun sa bukasan ng tanke na diesel..sabi nung gasoline boy bihira daw kasi ung diesel sa oner type jeep ayun..tinanggal lahat ng laman at pinalitan nila kung gano karami ung laman ng tangke ganun din ung ipinalit..
August 20th, 2017 07:48 PM #24
Kung naging mas mausok na kulay puti ang buga ng tambutso mo kaysa dati then may diesel nga nahalo sa fuel mo.
- Jan 2017
- 429
August 20th, 2017 07:57 PM #25
August 20th, 2017 07:58 PM #26
Putting Petrol Into A Diesel Car #TBT - Fifth Gear - YouTube
Sent from Zenfone 3 on Tsikot mobile app
August 21st, 2017 10:17 AM #27
Baka namalik mata kalang TS, naramdaman muna dapat yan sa tinakbo mo. Happens to us long time ago sa petron naman, oner naman gas engine 4k kinargahan ng diesel. Mga 2kilometers palang tinakbo tumirik na eh,good thing mag malapit ma talyer kung saan tumirik. Pag open nila ng carburador amoy diesel, balik kami sa petron ayun deny to the bones ang gasoline boy which we forgot to take the receipt.haha
Drain lang ung tank ng oner and lininis ung line and carb and changed spark plug.
- Jan 2017
- 429
August 21st, 2017 12:17 PM #28
August 21st, 2017 04:04 PM #29
How did you confirm that you loaded diesel? If it's just because of the nozzle jacket, it's actually highly likely that they just mistakenly put a black jacket on a gasoline nozzle.
Gas and diesel nozzles are exactly the same, but if you're driving a sedan I don't think you'll get a misfill.
Most common misfill vehicles are Innovas, Tucsons, and Fortuners because all of them are offered in both gas and diesel variants.
August 21st, 2017 05:10 PM #30
i'm a yokohaman. altii, innova, wigo. ordinary driving. no issues.
Finding the Best Tire for You
