Results 571 to 580 of 2348
- Aug 2009
- 6
August 19th, 2009 11:53 PM #571Thank you very much Dieseldude really appreciate your input.
Just like to clarify something.
I have received FIP technical report from the casa and here are the following information.
Subject: Abnormal wear on Cam rollers and cam disk
Failed unit name: Distributor injection pump
Failure details:
1. Abnormal wear of the roller assembly.
2. Burnt/Discoloration of the cam disk surface.
Investigation result:
Worn out roller assemblies and scratches of the cam disk.
Burnt/discoloration/wear of the roller assembly and cam disk surface may be caused by contaminated diesel fuel.
Conclusion:
All moving parts are lubricated by diesel oil.
Comment: Replacement of the rollers and cam disk necessary.
My questions are the following:
1) What are the function and use of the roller assembly and cam disk?
2) What can be the cause of the abnormal wear of the roller assembly? Can this be caused by the water contamination?
3) They say there are scratches, is there a possibility that there are solid contaminants that is not caught by the fuel filter, hence a failure in the fuel filter?
4) What can be the cause of the burnt/discoloration of the cam disk? Why is this unusual?
5) Can you explain further on the conclusion where all moving parts are lubricated by diesel oil? Is this unusual?
Thank you very much again on your help on this.
- Sep 2006
- 1,335
August 21st, 2009 03:25 AM #572Thank you very much Dieseldude really appreciate your input.
Failure details:
Conclusion:
All moving parts are lubricated by diesel oil. Yes..
1) What are the function and use of the roller assembly and cam disk? The roller assembly rides on the cam disk. These work together to rotate and stroke the plunger for injection.
2) What can be the cause of the abnormal wear of the roller assembly? Can this be caused by the water contamination? Yes.
3) They say there are scratches, is there a possibility that there are solid contaminants that is not caught by the fuel filter, hence a failure in the fuel filter? Very remote.
4) What can be the cause of the burnt/discoloration of the cam disk? Why is this unusual? Poor fuel lubricity, and/or water. You might have to evaluate your fuel source...
5) Can you explain further on the conclusion where all moving parts are lubricated by diesel oil? Is this unusual? No. By design, this specific pump type uses diesel fuel to cool and lubricate the internals.
Thank you very much again on your help on this. You're welcome.
- Sep 2006
- 1,335
August 21st, 2009 10:53 AM #573hello diesel dude,
mine is an XT 05 model...hindi naman po tubig ang naisalin kundi gasolina ng aanga-anga na gasoline girl sa Petro Sto. Tomas Batangas...ako pa ang nakakita but too late nakapagsalin na ng 2.5 liters, medyo buwenas pa din at naturn-off ko engine before filling...so here is what we did..
1. Drain ang diesel tank...
2. Remove hose from fuel pump and filter and manual bleed.(Ang bilis pumanik ng gasoline andun na agad sa mga hoses..
3. Remove the supply hose to fuel injection then bleed ulit until the gasoline smell and color was gone.
after ng matagal na bleeding..start and one click naman po. Tama ang ginawa nyo.
Question...ano po mangyari kapag napasok ng gasoline ang fuel injection? masisira po ba? Hindi naman masisira agad ang fuel injection kung minsan lang ito mangyari. Matibay ang construction ng injection pump. Masisira ito kung madalas ginagawa dahil kulang sa lubricity ang gasolina.
then sabi nung bayaw ko yung mga byaheng jeep sa tanay rizal, hinahaluan daw ng konti gasoline ang diesel para malakas ang hatak at naputok ang muffler kapag hinataw...I dont know if it is true... Hindi ko rin alam yan. Sa palagay ko lang, hindi magtatagal ang engine dahil sa pre-ignition. Masisira din ang injection pump nang maaga.
Lesson learned...hindi na ako ulit mag-pa diesel dun...hindi maganda ang service.. Wag naman. Nagkamali lang ang gasoline girl. Hindi sadya iyon. Siguradong hindi na nya uulitin yun dahil nakita nya kung gaano kahirap mag drain. Malamang, pinagalitan pa sha ng manager nya...
thanks... Welcome..
August 24th, 2009 01:30 AM #574
Dear Dieseldude:
Hi Jake! Its Dusky Lim.
Sir, I have a friend with a 2003 Isuzu Trooper with an unusual problem.
Lately after a trip to the province, the engine stopped with a fuel warning light on. After checking the separator, they found some water mixed in with the fuel. They drained the water and had the tank checked. There was some water in the tank so they drained the tank too and refilled with fresh diesel fuel.
After cleaning and purging the fuel line, everything seemed to be ok but after a few kilometers, the fuel warning light came on again and the engine stopped.
While doing other routine checking, the driver found Diesel Fuel in the Radiator! It appears that the somehow the fuel is mixing with the engines water and it's all running back to the tank via the return line from the injectors.
Have you any experience with this sort of problem? Is there a seal in the injectors that connects with the water jacket?
INTECO claims that the cylinder head is cracked and that is the cause of the leak. That may explain diesel in the water but not water in the diesel.
They would appreciate any advice you can give.
Thanks a bunch,
Dusky Lim
- Sep 2006
- 1,335
August 25th, 2009 12:59 AM #575Hi Dusky,
I have heard of this problem, but haven't had the chance to work on one.
I know somebody though who has lots of experience on this. I'll ask ask him and give you feedback soon.
Bye,
Diseldude
- Jul 2009
- 99
August 26th, 2009 05:57 PM #576hi sir,
i am new to this thread. hope i have something here to help.
the injector of a deisel engine is either threaded to the cylinder head or pressed hold by a clamp also hold by a bolt threaded to the cylinder head. since the injectors are exposed outside the engine, it has an o-ring on its outer housing when inserted to prevent water or dush from entering through the hole where the injectors are threaded. it also seats on a copper washer that serves as a spacer between the injector and the cylinder head.
if the cylinder head has a crack, there is no way the water on the water jacket will enter the injector since there is no physical connection between the fuel system and the cooling system even with a crack water jacket.
the contamination on the radiator that you said a deisel fuel is not a diesel fuel. if the cylinder head is crack, it is posible that the oil from the oil passage int the cylinder head is mixing with the water on the water jackets. be sure to check if the contamination or discoloration on the radiator water is really a diesel fuel.
base on your findings, you only check the fuel water separator. i hope you also replace the fuel water separator and the fuel filter after cleaning and draining the fuel tank.
as for the crack cylinder head, probobly, hte unit has an overheating problem or history before that cause the crack.
hope i helped.
- Jun 2009
- 29
August 26th, 2009 10:09 PM #577gud evening po mga kuya's,
may tanong lang po ako,
1.)hindi po ba masisira yung fuel injection kung byabyahe namin na may leak pero pag mainit naman yung makina wala naman ng tumutulo pag start lang po ng umaga yun my leak, yung oring po yata ang my problema ayaw po nila galawin dito sa isabela yung fuel injector kasi daw po electronics baka raw mag iba yung andar ng makina?2.) my alam po ba kayo na EFI shop dito sa isabela or sa madadaanan namin papuntang pampanga?
maraming salamat po
- Sep 2006
- 1,335
August 27th, 2009 02:04 AM #578gud evening po mga kuya's,
1.)hindi po ba masisira yung fuel injection kung byabyahe namin na may leak pero pag mainit naman yung makina wala naman ng tumutulo pag start lang po ng umaga yun my leak, yung oring po yata ang my problema ayaw po nila galawin dito sa isabela yung fuel injector kasi daw po electronics baka raw mag iba yung andar ng makina? Tama sila. Baka lalong lumaki ang problem kung wala silang equipment pang test nito.2.) my alam po ba kayo na EFI shop dito sa isabela or sa madadaanan namin papuntang pampanga? Sorry, wala akong alam na makakagawa nito sa area mo.
maraming salamat po You're welcome
Ano ba ang make and model ng sasakyan mo?
- Jun 2009
- 29
August 27th, 2009 02:09 PM #579LC 70 po, diba masisira lalo yun kung byahe namin dito sa isabela papuntang pampanga? di pa po namin maipapagawa dito kasi wala po yata sila gamit na pang EFI.
thanks po
- Jul 2008
- 935
August 27th, 2009 09:51 PM #580hi sir dieseldude...
tanong ko lang sana kung paano magdrain ng water sa fuel filter...my van has a 1KZ-TE engine, super custom yung galing subic...
tsaka nakakasira ba ng ECU pag may welding job sa body?
TIA...
Ang nakikitang kong positive ng PPF is if the time comes to sell your car, you can remove the PPF....
Ceramic Coating vs PPF (Paint Protection Film)
