Dinamay pa ako heheheheh... :wink:
Speaking of Glenn, what is his exact store adress pala?
Hi Hitman,
It would be good if you can bring along a mechanic so that he could check the engine of the 2nd hand ride.... para sigurado.
Also, try knocking around the AUV, to check if it has 'collision damage'. Yung use your knuckes and knock around the body.
Tapos look under the place where its parked, to check for leaks. Dapat walang puddles of oil, water and what-have-you.
Tapos TEST DRIVE ninyo... pag-ayaw nilang pa-test drive, then do your own driving, as in drive away as far as possible from them... hehehehe..
