Results 1 to 10 of 21
June 15th, 2009 12:14 PM #1
is using compressed air when draining the engine oil ok?
every time i do oil change the gas station always use compressed air to push out used oil from the engine.
i've been doing this to my 3 vehicles for a long time now.
just wondering if there are bad effects when doing this.
- Aug 2003
- 9,720
June 15th, 2009 12:52 PM #3hmm, i remember an earlier discussion on this topic. i think there's a chance that some water/condensation could settle in the air compressor hose...so you may be effectively blowing water into your engine.
imho patuluin mo na lang ng maigi; pag di ako nagmamadali pinapatulo ko siya overnight. anyways whatever residual dirty oil is probably going to get very very diluted in the new oil you're putting in.
June 15th, 2009 06:14 PM #4
June 15th, 2009 06:49 PM #5
that's why i prefer DIY for maximum draining interval (naturally). but gas stations done these things before to speed up the draining and wala naman problema but we can also request them not to use compressed air if we want. natural draining for me.
June 15th, 2009 08:34 PM #6
Ok lang siguro kung may moisture trap o air filter. Gaano ba karaming moisture para makaapekto sa performance ng langis? Anyway, better be safe than sorry. Researh pa siguro..
- Apr 2009
- 59
June 15th, 2009 08:36 PM #7You can ask the mechanic/technician to DRAIN any water (if any) from the compressor tank. Further, you could ask if there is a water filter attached to the outlet end/hose of the air line.
Like some of you i do my own fluid changes. I like changing my oil after a good drive so the oil is hot (BE CAREFUL Not to get BURNED!!! Use gloves or a thick durable bag over your hand and forearm) and flows out better. I`m not a chemical engineer, but thats what i understand.
June 15th, 2009 10:30 PM #9
Come on... just the act of compressing air and then releasing it would make water vapor condense into micro droplets. This is especially true with the big air compressors used in gas stations.
- Apr 2009
- 59
June 16th, 2009 07:26 PM #10GHOSTHUNTER- I`l probably take your advice on just starting and warming up the car, thanks!
I should probably refrain or not give advice at all to questions any more "technical" than like , "got the tel. no. for so and so shop in banawe.."
I think i`ll just stick to asking questions on this forum instead until the day comes that i become as QUALIFIED as people like you.
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
