Results 1 to 18 of 18
    Apr 2014
    For the past 2 months I noticed na pahina ng pahina ang hatak ng Corolla GLi ko lalo na pg nka on ang aircon ...
    Last two days, bigla na lang nawawalan ng pressure ang clutch pedal at hindi kumakagat ang gear ... Pinagawa ko kanina sa mekaniko at ang diagnosis ay may gasgas na sa loob ng master cylinder kaya hindi maka sustain ang pressure at nagiging soft ang clutch pedal ..
    Pinalitan ng replacement master cylinder .. at habang ginagawa, binuksan ko airbox at tinanggal ang air filter at grabe talaga ang na accumulate na dumi kaya pinalitan ko na rin ng replacement ..
    Kanina habang ginagamit ko yung kotse, malakas na ang hatak at nawala na ang jerking sa 1st at 2nd gear .. kahit naka on yung aircon at full load, madali nang mag accelerate ..
    Ano kaya ang nag cause ng mahinang hatak at jerking while on 1st & 2nd gear ?? yung busted clutch master cylinder or air filter ????
    Probably air filter. Hahaha. Those things need cleaning monthly.
    Quote Originally Posted by Dezaremos View Post
    i think all that air filter gunk was preventing air (oxygen) from getting into the cylinders.. you have fuel, but without oxygen, you can't burn the fuel for power.
    and if i may comment... when was the last time you checked that filter, sir!
    Jun 2008
    My bet is air filter. Dapat linisin yan weekly para di maipon dumi.
    Quote Originally Posted by ;2703335
    i check mine every 5000 km (at least 6 months, mebbe even 10 months), and it never reached the point of asphyxiating the engine. and it's easy to clean.
    Apr 2014
    I bought this car last year as 2nd hand, and it was really a good buy because the previous owner was an old Chinese businessman who loves cars and have lots of cars .. he said he only bought this corolla GLi because at that time this was the best car to own during the 90's ... All he did was proper maintenance and use the car from time to time aside from this other cars ..
    When I bought it from him last year, I never bother to check the air filter because the engine sound was superb and the car was running smooth at powerful ..
    It was just now that I check the air filter and its really full of dirt .. aside from that, I think the previous owner just cleaned the filter but never replace it .. Because I think it was still the original Denso Air Filter ..
    oh well... it's just an air filter.. easy to replace..
    so, is the rest of the car as good as it promised to be?
    pssst... baka may iba pa siyang... PM me...
    May 2009
    for me, i really don't clean the filter. pinipitik pitik ko lang yung metal casing ng filter para matanggal yung coarse materials. vinavacuum ko lang yung loob ng air filter box assembly. hindi ko binubugahan ng hangin yung mismong air filter. kasi sa aking opinyon (at sa nabasa ko rin sa isang diesel motoring mag), nagiging kasama na rin as filtering material yung dumi na kumakapit sa mismong air filter. thus mas nagiging pino ang filtering habang ito'y nagagamit.
    btw, ayokong magstart ng debate rito ha..hehe
    what i mean is palit at the recommended (oem) interval.
    Jun 2008
    2x a month I check/clean the engine air filter. I keep the OEM filter pero nilagyan ko ng filter mat layer. Filter mat lang ang pinapalitan ko ng pre-cleaned spare.
    Sent from my Lenovo A7000-a using Tsikot Forums mobile app
    Dec 2015
    Anyone tried an AEM dryflow filter?
    Sent from my MI 5 using Tapatalk
    Sep 2016
    How do you guys clean your air filters?
    Sep 2016
    Pa OT lang mga sir! Hindi ko kasi alam kung may thread na dito about sa "Clutch".
    Matigas tapakan, malalim na yung tapak niya, maingay parang squeaking noise kapag tinapakan siya, at parang may buhangin yung pakiramdam sa paa kapag tinapakan yung clutch ko. Medyo nabibigla na din yung bitaw ng makina pagtapos kumambya kasi masyado nang malalim yung clutch ko. At lastly, whenever the vehicle is running or stop and nasa idle, mayroon akong naririnig na ticking sound sa engine bay near to the driver's side at nawawala lang siya kapag tinapakan ko yung clutch or kahit pinatong ko lang yung paa ko sa clutch pedal at medyo bumaon.
    Ano po kaya ito mga sir? Salamat po in advance!
    Jun 2005
    Quote Originally Posted by Offroad_Goals View Post
    Blow compressed air sa air filter. It should be opposite nung higop pa engine
    Jun 2005
    Vios ba itong oto hehe.
    Your clutch components might already need replacement (pressure plate, disc, relase bearing) and may need checking/reface sa flywheel.
    Apr 2009
    Quote Originally Posted by sirkosero View Post
    Sa na experience ko sa service namin, pressure plate yan. delikado na gamitin yan may chance na mag lock at tumirik. I suggest you have it repaired immediately. mahal ma tow gastusin mo na lang sa pa repair.
    like sirkosero said need replacement na clutch parts mo and pati clutch master and secondary pa check mo na rin para wala ka ng worry.
    Apr 2009
    Ako pinapagpag ko lang. Mura lang naman replacement air filter ginagawa ko sa vios ko every
    5000km thats 2 years na gamit replaced na.
    Oct 2009
    palitan nyo nalang.pinaka maganda.pero ako tutal may compressor ako.buga lang siya ng hangin.pero pag sobrang dumi na talaga binababad ko sa pinag labahan ng mga damit namin..simota air filter
    Jul 2012
    madumi airfilter nyan, hindi na makahigop ng hangin, thus na sense ng ECU na konti lang ang air, kaya kinontian nya din ang fuel for the mixture, resulting to low power
Clutch Master or Air Filter ???
