Results 1 to 19 of 19
    Jul 2016
    chevy optra matic unit ko.
    binabaybay ko kahabaan ng nlex ng biglang namatay engine ko speed at 80-100. (kung kelan nsa nlex namatay , nun nsa traffic hindi)
    then hard start n sya. pinag pahinga k lang ng ilang minuto ok na uli.
    ANO PO KAYA ISSUE NG AUTO KO? SALAMAT SA MGA SASAGOT ! ! !
    Overheating engine? Check temp and radiator water level.
    Sent from my SM-N930F using Tapatalk
    Quote Originally Posted by YooShh17 View Post
    Check your fuel filter and fuel pump.
    Several possibilities from a fuel pump, to crank sensor, to a clogged fuel filter, to ignition (is the Optra direct ignition or utilizes an ignition coil?). You will have to observe and check these items one by one and have a scan done as well perhaps.
    Jul 2016
    not overheat sir 1/4 lng halos temp ko.
    ok water level
    Jul 2016
    ngayun...
    check engine light on naman sya. nag pa karga lang ako fuel eh pinatay engine ko. pag start ko d agad nag start misfire lang tapos nag start n sya sa 2nd try ko.l tpos lumabas na check engine light... help!?
    Sep 2009
    Well, that leaves you no choice but to bring it over for a repair. Better if you could have it towed.
    Since may check engine light na, theoretically mas madali na ma-pinpoint kung ano ang problema talaga ng car kapag mapabasa mo sa shop na may obd ii scanner
    to be or not to be, that always confuses me!
    Apr 2012
    korek ka diyan bro. obd scanner lang ang makakasagot sa sa check engine ng car ni TS at ng malaman niya ang error code.
    kapag nalaman ang error code, pwede ng itanong kay google o kaya sa mga tsikoteers
    Sep 2014
    Hi-tension wire yan, pag mabilis ka nag hi-tension si kaya nasira na, pero pag traffic ok lang
    Palit ka hi-tension wire
    _________________________________
    If you are wrong, turn right.
    If you are right, turn left.
    Jul 2016
    check engine light already resolved po open ko lang un gas cap ko then open close. ok n sya see video.
    so far nmn po nun bmiyahe kmi knina calumpit to angeles no tirik temp at 1/4 or near to half
    Apr 2012
    it's only a band-aid fix nandiyan pa rin yan not unless malaman mo yung error code na nag-cause ng CEL.
    Apr 2016
    better to have it checked, kc usually ang check engine light kht mawala yan nag pepersist parin ung problem, I experienced na nag ddownshift ako when i run to tagaytay AT light turned on and CEL also, then pina reset ko ung computer ng car ko then nawala CEL but the problem of downshifting still persist so as soon as i went back to my place dinala ko agad sa mekaniko ko then only to find out that one of my sensor is already malfunctioning. and some bands inside the transmission. so bring it to ur nearest talyer kesa lumala sira lalo na at mukang engine yan
    maybe cam sensor, madalas sakit ng optra but better ps scan mo muna
    Jul 2006
    Seems like you have a clogged tank breather. The fuel tank is vented into the atmosphere for the fuel pump to suck gasoline.
    If said vent is clogged, your fuel pump is restricted. In some cases, gas tanks are known to crumple.
    see here:
    What happens when a tank vent gets clogged. - PeachParts Mercedes ShopForum
    Vent valve, how it works, symptoms, problems, testing
    Aug 2015
    pwede ka talaga mag CEL sa gas cap na hindi maayos pagkaka balik. It is a common trigger, so kung hindi na naulit that might be it. to be extra safe pa scan kung may code.
    Jul 2016
    Quote Originally Posted by unmarked View Post
    oo nga eh kasi bos nag pa gas lang ako nagkaganun na. then check ako sa bahay research sa google . un nga gas cap so tinitry ko ayusin. ok na wala ng CEL
    see here:
    thanks sir
    ano po ba dapat ko icheck pag bibiyahe ng malayo? this sunday po kasi biyahe kami isabela provice. ? thanks
    Aug 2015
    thanks sir
    BLOWBAG sir:
    B- Battery
    L- Lights
    O- Oil
    W- Water
    B- Brakes
    A- Air
    G- Gas
    Jul 2016
    BLOWBAG sir:
    B- Battery
    L- Lights
    O- Oil
    W- Water
    B- Brakes
    A- Air
    G- Gas
    ty very much
Bigla namatay engine habang nasa nlex..
