Results 1 to 13 of 13
    Aug 2006
    Hello fellow tsikoters..
    just a quick question regarding the scenario na nangyari sa akin this monday..
    i was in Autoline to install a new tint, shempre..in order for the installer to install the tint sa mga side doors ko, hee needs to turn the ignition to on for almost 2 hours ata yun..kasi ganun katagal mag lagay ng tint, after that..yung pag alis kona..start ko yung engine...1 click start na siya..pero nangyari is parang humina yung rev niya..despite cold start yun..kala ko normal lang..pag atras ko then brake..umilaw yung check engine ko then my rpm drops from 1000 to 500 then after that shempre..rev ako ng rev pero naka ilaw padin yung check engine ko..
    after ko pinatakbo ng mga 5 minutes (komakatjot yung takbo na parang sakal..) then pag brake ko, sabay rev ko ng tudo, then suddenly nawala ng yung ilaw sa check engine ko...
    since then till now hinde na umulit..
    ano kaya cause nun?
    sabi ng mechanic ko is to just reset it by removing the negative pole from the battery and put it back in..
    doubt ko yung pag on ng ignition ng matagal...may ganun factor ba mga gurus..
    please help..
    thanks for viewing..your response will be greatly appreciated, engine ko pala is silvertop 2.0v
    Jan 2008
    double post
    Jan 2008
    Ipa - Diagnostic SCAN mo kaya. Pero sino kaya my scanner dito that covers your engine. Baka si sir 'speedyfix' makatulong.
    San ka kaya nagkulang sa karinyo dyan sa kotse mo
    Feb 2007
    Try mo muna reset baka umayos yan.
    OT: earthlyken, bakit kailangan i-turn "on" yung ignition habang kinakabit yung tint?
    Aug 2006
    ok na pala oto ko...pina diagnostic test ko, battery or kuryente lang daw naging problem..
    pero ok na siya now...
    thanks sa lahat
    ako din, hindi ko gets kung bakit kailangan nakaON yung switch para sa tint... do they move it up and down? yung painstall ako ng tint, hindi nila pinaON yung ginition key ko...
    hmm... parang weird yun ha?
    sorry for the OT, curious lang din.
    May 2007
    Quote Originally Posted by earthlyken View Post
    thanks sa lahat
    Very good. Now, you that most newer car that if you use your batt.(engine off) for so long and draining almost to the limit of the cranking capacity of your car the check engine ligths will come on. If your battery still good and your charging system that check engine will reset itself as soon as the battery brought back to level.
    Nov 2003
    leaving the ignition on will not result in the CEL appearing.
    Nov 2006
    Quote Originally Posted by speedyfix View Post
    sometimes it does,when the bcm detects that the voltage below threshold,it may not communicate with the ecm and now the ecm act erratically until the bcm mets the cycle (voltage cylce,ignition cycle,etc.).and the reason why the check engine light went out,thats because they met the cylce but the dtc still there and it is set as history in ecm.only scanner can clear them or by removing negative battery terminal 15 seconds or more.
    entertainment or air or both,thats probably the reason why the installer needs to turn the ignition on.
    Aug 2006
    Quote Originally Posted by dennis powell View Post
    wow...so are you saying that mangyayari ulit yun? dahil nasa histoory na niya?
    Nov 2006
    no,all codes that sat as history are no longer active,its just telling you that the ecu encountered problem previuosly.unless that concerned reappear, then it will, but this time is as current.
    Baka accessories/acc lang and on at hindi ignition/ig.
    Nonetheless acc can still drain the battery because of pilot lights and sound system.
    Its also possible na charge light lang yung nakita mo.
    If its really ignition that was turned on, did you ask him why does he have to leave it on?
    Sir Dennis is correct the ECU/ECM must always have enough power for it to run operations if not it will not let the engine run or shut it down (sometimes derate or limp)
    Nov 2003
    if that's the case just remove the battery for 30 seconds and it shouldn't happen again.
Check engine light on and off
