Where can you find the air intake adjust valve of a Honda Civic '04?
Vti M/T
1.6 VTEC3 engine
eto kasi
everytime i kick the throttle and suddenly release it, the RPM dives to about 300rpm or lower for less than two seconds then goes back to the normal 750-800. Sometimes, the engine completely stalls. The bad part is that it usually happens when moving, so when shifting, at high speeds, the engine stalls sometimes and i have to restart.
It happens while moving most of the time. But when parked, it happens but most of the time it's normal (drop to about 1000rpm and down to 800rpm). Only when moving or "gliding" lang talaga.
Wala naman problem ang engine itself, malakas ang hatak and can rev to redline without bad signs.
Our trusted mechanic said its most likely because of the air intake, but he couldnt find the adjusting valve. Does anyone know where it's located? Near what? any pics? thanks!
