Results 1 to 15 of 15
    Naniniwala ba kayo sa article na ito sa
    http://www.mototuneusa.com/break_in_secrets.htm
    Ang bottomline ng tip eh 'wag sundin ang recommended break-in ng car manufacturer - mas maganda kung high revs ang takbo pero bago ito gawin, full warm up muna. Tapos puro mineral oils muna habang di pa nag-seat ang piston rings (upto 10,000 Km).
    Ako naman, pag brand new, tinatakbo ko agad sa Ilocos or Baguio. As for using mineral oils before reaching the 10,000km. mark, tama iyan.
    May 2005
    umm sige, sino mauna..
    taken from mymitsu ito diba?
    basta sakin rule of thumb..ang sobra ay laging nakakasama.
    i have no idea who this guy is...and these are some really controversial statements that he's making...
    but as i read through the article, some of the stuff seems to make sense. of course, i'm no automotive engineer, but i know a little bit about how engines work.
    Feb 2006
    I have 2 questions po:
    1.) What exactly does "proper warm-up" mean? For me, it's keeping the engine under 3000rpm for the first 5 mins after a cold start. Tama ba?
    2.) I had a '93 Lancer 1.6GLXi. My break-in (too undisciplined to follow manual ) was keep the rpms under 4000. Top speed is 120 km/h. I feel that because of this, up to '96, it was the best performing stock GLXi anywhere (ESi - wala yan!). Up to '96, I could even kick VTEC ass. Mileage was 9km/l. By '97, bigla wala na... even lousy slow GLis (no offense po) can beat me. Mileage deteriorated slowly until 7.5km/l nalang. What happened? The maintenance routine did not change... Why after 3 years the love was gone? After reading the piston sealing, I wonder... Can anyone theorize what happened?
    Aug 2004
    I do remember fighting long and hard over this crackpot theory a long time ago on another board... I don't really remember what we decided about it though...
    Just one observation: There's a reason media test-drive units drive like crap compared to privately owned cars after the first ten thousand kilometers have gone by.
    Still, with delivery mileage on test units already in, those first twenty miles he's talking about are often used up before you get home!
    Many manufacturers don't require an "easy" break in any more, as part tolerances are tighter, but it's cultural inertia, I guess, or habit that we don't like running engines hard for the first 1000 km/
    Feb 2006
    Use mineral oils until 10k??? Uh oh... I just had my Altis' very first 1,000 km checkup/tune up with Toyota and I asked for fully synthetic oil. They didn't say anything about using mineral oil until 10,000 km. Am I doomed?!?! What should I do??? Help!!!
    Quote Originally Posted by manilenio
    DOn't listen to what that article says... ;)
    Sorry for scaring you, it seems I was still sticking to the old recommendations.
    # MYTH: You need to allow a break-in period for new vehicles before using synthetic motor oil.
    FACT: In the past, it was recommended that conventional motor oil be used for your first oil change to allow for some controlled wear to break-in the new engine. However, with current engine technology, a break-in period is not necessary. You can use synthetics immediately.
    Aug 2004
    Tama nga si falken, the drawbacks of running the engine hard or using synthetics during the first 5-10 thousand kays are largely past. But unless you are on 10k change sked, you don't need synths. If you drive like me, though, synths aren't a bad idea.
    Feb 2006
    Hay, thank god! I was really alarmed. Thank you very much Falken for clearing the air regarding this issue.
    ganyan ginawa ko sa scooter ko, i also followed the 20 mile change oil, grabe yung metal particles, kitang kita sa oil yung mga metal flakes....not sure lang sa mga cars, pero whenever we have a new car we make it a point to bring it to baguio via kennon. so far positive results naman
    Dec 2002
    Quote Originally Posted by trup
    Dropby muna sa Manaoag para ma-blessing ni Father sabay kabit ng sticker nila, so far positive results din.....wink!
    'Eto pa ang mecahnical explanation.
    http://www.ntnoa.org/enginebreakin.htm
    So far ginagawa ko ang hard break using mineral oil sa past 3 cars ko, no problem naman.
Break it HARD (Engine)
