Results 1 to 14 of 14
    Jan 2003
    is this realy needed?
    na siraan ako sa road kanina. pag ni revolusyon ko makina parang nabubulunan n namamatay. mga 8pm po yon
    so tawag ako AAP para tow sa bahay yng car.
    nong dumating truck sabi barado na air filter. so tinangal nya n ok na andar ng kotse. bumili n lang daw ako ng pampalit. wla nang stores na open sa umuwi ako ng wala air filter.
    tanong pwede ba wala air filter ang car?
    if no , how long can i drive without the filter, before causing a bigger damage.
    thnx
    Aug 2003
    hmmm...imho they put air filters in cars for a reason B)
    in your case sir, the filter was clogged, so zero air is going in, hence no combustion; pag wala namang filter, dirt, bugs, excess moisture is bound to accumulate in the engine, interfering with its operation. i guess the air filter is something in between those extremes
    Oct 2005
    think of your engine's intake as your nose pare. and think of your nose hair as your car's air filter. kapag wala kang buhok sa ilong, marumi ang hangin na papasok sa yo. hindi healthy yun deba? ngayon kapag makapal ang buhok mo sa ilong ok sya, nafifilter. pero kapag hindi ka nangulangot (naglinis ng ilong), hindi ka makakahinga diba? same as with your car.
    Jan 2004
    sir mura lang ang air filter. bili ka na lang. better yet, you buy those washable K&N filters. medyo mahal pero malaki matitipid mo in the long run, ganda pa nang throttle response.
    Aug 2004
    As for how long you can run it, try not to go for more than a day. Old school racers run without filters, just put stockings or fine mesh over the hole to keep debris out (fasten the stockings tightly, or they'll get sucked in). If you drive too long without a proper filter, you'll risk damaging your sensors.
    Jan 2003
    ok thnx
    generallty baw how long ang life ng stock air filter? 10k kms?
    Aug 2003
    time ata ang measurement, not mileage...pero pag buo pa ung filter, pwede pang linisin right? i've seen a couple of shops use a compressor to clean air filters...ewan ko lang kung effective ba
    Oct 2005
    diba ang advise sa manual at sa casa every change oil dapat nagpapalit ng air filter? except for washable air filters which can be used over and over. kasi yung mga air filter na oem ay pang isahang gamit lang. alam ko nakakaapekto rin ito sa quality ng langis. kapag accumulated na ang dumi sa intake mechanism, posibleng marumihan na rin ang oil...tama ba?
    Quote Originally Posted by umzzzzz
    ok sa example ah. hinango sa pang araw-araw na buhay. hehehe.
    seriously, umzzzz example is how air filter works...imagine the air in metro manila going inside your combustion chamber..
    mura lang talaga stock air filter. my lancer's stock filter costs around 180 petot each...
    Aug 2004
    ok narin siguro magpalit ng stock air filter every other oil change. pinapalinisan ko nalang ng hangin sa fuel station once in a while para matanggal mga alikabok.
    Nov 2003
    di na kelangan linisin yung mga stock filters. they are so cheap, just replace them
    BAka po Oil Filter yon hindi Air Filter
    May 2005
    Quote Originally Posted by NightRock
    air filter yan.
    OEM air filters are replaced every 5000-10000kms depending on road conditions.
    oil is directly affected by dirt entering the air intake of the car. that's why racers running open air intakes (no filter) replace their oil more often coz mabilis dumumi ang langis nila.
    On my rig, paper air filter replacements are prescribed every other oil change. Otherwise, cleaning with compressed air is recommended.
    But since I use replacement air filters, I can afford to change at every oil change.
air filter ng cars
