Results 1 to 7 of 7
- Jul 2009
- 38
November 9th, 2011 07:38 AM #1mga paps baka may suggestions kayo,yung blitz bov ko kasi ayaw suminga, naka ilang adjust nako dun sa screw ayaw talaga,ang tunog nya parang huni ng ibon parang "peeeeeeeewwwww" imbes na wapish! dati kasi pag binibirit ko 3 to 4k rpm pag let go ko ng throttle "huwaaaapish" na tunog eh ngayon parang kuliglig eh ,eto ba yung turkey sound chaka compressor surge na tinatawag, anu pa ba pwede i adjust para suminga ulit? thanks
toyota 4efte engine pala,1.3 liter turbocharged
- May 2011
- 481
November 9th, 2011 02:46 PM #2
- Jul 2011
- 447
November 9th, 2011 02:50 PM #3
- Jun 2011
- 134
November 10th, 2011 09:33 PM #4Sir,bka may boost/vacuum leak ka.kung may boost gauge ka,ma check mo kung mababa ang boost pressure at vacuum.
- Mar 2004
- 434
September 30th, 2012 08:12 AM #6sir , try to adjust the screw outward. then feel the blow off valve in the engine compartment by revving the engine and feeling if there is air blowing off the BOV.
ofcourse, you are doing this while stop and the hood is open. and preferably with a buddy so you can focus on the BOV and let him do the revving.
additional - if your bov has been working since and you have not done anything to the engine. theres a big possiblity that it is already broken. try to replace with a working unit from a friends car.Last edited by baker123; September 30th, 2012 at 08:20 AM. Reason: additional info
October 1st, 2012 10:36 AM #7
high idle RPM at engine start
