Results 1 to 10 of 13
- Apr 2009
- 1,902
September 10th, 2010 06:45 PM #1I'm thinking of DIYing this project on a lazy weekend.
Basically, I'm thinking of installing a fuel filter in the hose line from the PCV valve to the carb intake.
I have no idea how much oil catch cans sell and where to easily get them, hence the fuel filter popped in my mind.
My engine is carburator-fed so I don't worry much on faulty ECU readings.
Has anybody tried this already?
Any possible effects I could expect on engine response, emissions etc?
[SIZE=1][/SIZE]
[SIZE=1]Anyway, I found a similar thread about this but it's more on Isuzu diesel engines and EGR systems.[/SIZE]
- Jan 2008
- 380
September 11th, 2010 08:07 AM #2This could extremely increase the crankcase pressure, blowing your engine into a piece of crap.
- Apr 2009
- 1,902
September 13th, 2010 06:09 PM #3I see.
I thought it could serve the same purpose of an oil catch can.
Thanks anyway.
I did not proceed with the project.
September 15th, 2010 09:03 PM #4
[QUOTE=isa1023;1558233]I'm thinking of DIYing this project on a lazy weekend.
Fuel filter ang gamit ko yong plastic ok naman may mga oil na catch mga 1/8 ng container kapag naka 1000 kilometers ka.atleast na catch kaysa papasok sa carburator maging bad emission pa mga 5years ko nang ginagamit walang bad effect
- Apr 2009
- 1,902
September 16th, 2010 07:21 AM #5Originally Posted by adamsapple
Medyo oily na rin kasi yung PCV system ko baka palitan ko yung mismong valve muna.
Lakas na rin kasi ng emissions due to busted valve seals.
September 16th, 2010 10:12 AM #6
I once planned na palitan yung pcv valve ng pipip ko which is 4d56t powered.
kaso nung natanggal ko na valve cover, may riveted plate covering pa yung pcv valve.
any idea how to change/remove the pcv valve in my case? any info would be appreciated.
my plan this coming october is to recharge my A/C and change the drier to a new one since mahina na rin A/C ko.
then get the replaced drier and convert it to oil catch tank. mas matibay yun kesa yung plastic na filter. tatanggalin ko nga lang yung dessicant sa loob muna.
- Apr 2009
- 1,902
September 16th, 2010 01:10 PM #7Diba usually nakakabit lang yung PCV valve mismo sa grommet (usually a black rubberlike seal) sa valve cover?
... so that the PCV valve itself can be replaced ala-plug and play without having to remove the valve cover.
- Jan 2008
- 380
What I do is periodic removal and clean up of the intake manifold of my diesels.
September 19th, 2010 01:22 PM #9
Refer to my post on this thread for a DIY oil catch can system. Works great, pretty cheap.
http://tsikot.yehey.com/forums/showthread.php?t=72950
Here are the step by steps to do your own.
http://www.pbase.com/rsrock/oil_catch_can
- Apr 2009
- 1,902
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
