Results 441 to 450 of 1166
September 24th, 2019 11:58 AM #441
September 24th, 2019 12:38 PM #442
September 24th, 2019 12:46 PM #443
How can you tell if a VIC filter is real or not? Are there telltale signs on the product itself or the packaging?
- May 2017
- 2,099
September 24th, 2019 08:26 PM #445can someone post comparable photos of the original and fake VIC filters?
September 25th, 2019 12:52 AM #446Fasten your seatbelt! Or else... Driven To Thrill!
- Dec 2013
- 521
October 17th, 2019 03:22 PM #447There is a new announcement regarding the WIX brand of filters which will be readily available at 2 authorized online sellers located in QC and Pasig.
The current distributor is currently screening online sellers that they are going to appoint as authorized dealers.
F2 - ZIC / Kixx Dealer - Home | Facebook - Quezon City
Mrtata Automotive Supply - Home | Facebook - Pasig City
- Dec 2013
- 521
October 17th, 2019 03:39 PM #448
- Dec 2013
- 521
October 28th, 2019 04:26 AM #449Actually this double core filter is just a waste of filter space since they have 4 metal end caps per filter media lalo na since naka coil spring pa, in the most common of sense sa oil filter spin on type why would you need to put a inferior filtering capacity media at the top then another higher filtering capacity media at the bottom? When you can just put a one whole filter with higher efficiency filtration media sa loob ng isang can type filter? Why would you need to split two types one of an inferior media together with a better capacity one? It's just plainly aesthetics, if there is a lower capacity filtration at the top then the engine oil filtered will just contaminate the oil which is filtered by the bottom higher capacity filtration filter media. In the end you end up contaminating the better filtered oil with the poorly filtered oil.
- Dec 2013
- 521
October 28th, 2019 04:34 AM #450Also one of the VIC dealers said that during the presentation of VIC filters which they compared other brands like Sakura from Indonesia about the overall performance of their oil filter like filtration efficiency, pressure test, anti-drainback valve & etc... they have shown that VIC was only able to provide the maximum filtration capacity of 91%.
finally found a reliable bt obd2 thanks to travajante for referring kingbolen. then i modded so it...
Next-Gen Suzuki Jimny
