Originally Posted by
Freeman
These lube products are called "snake oils" by the established petroleum companies. I am not saying that this one is one of them.
If I remember right this was the explanation - these lubricant enhancers may contain chlorine, which attaches itself instantly to surfaces. This will cause the oil to bind itself to the metal components of your engine - even if the oil is drained - a film or chlorine will remain coated on the metal. Much like after we swim in a chlorinated pool, our skin is coated with a white chalky film. Anyway this is good for the engine, BUT in time the chlorine will transform into an acid (hydrochloric?) which will eventually be harmful for your engine. I do not know if an engine flush or oil flush will help in between oil changes.
If you have the resources and time - first do an oil flush using cheap oil. Put in your usual oil and add the additive. And after the lifetime of the oil have it analyzed by a lab.
