Results 1 to 20 of 24
    Mar 2003
    Bigay lang po sa akin ng pinsan ko. Kaso I am having hesitation na ilagay sa 4D56 TDIC ng strada ko. Safe po ba sa engine ito? :?: :?: :?:
    Mar 2003
    sirs,
    help me decide naman po kung ilalagay ko sa engine ko. Nanghihinayang ako kung hindi magagamit baka ok naman ito. Pero kung hnde naman safe sa engine itatapon o ipapamigay ko na lang.
    Imo, you could try the product as claimed by the users on the ads. But I would strongly suggest you DO NOT FOLLOW them when they drained the oil from the engine while running. Better fill it in when you have your next oil change. :D
    mangyan,
    if you're hesitating to test it on your 2.5 TDIC strada, i'm willing! :D
    tutal bigay lang pala sayo yan eh! :wink:
    sige na oh! :lol:
    No harm naman siguro iyan. Kung bigay lang I'm willing to pour it into my engine.
    Just don't expect them to deliver on the claims na nakalagay sa packaging. And they're overpriced, too. At least libre ang iyo.
    Mar 2003
    Sirs,
    hehehehehehe ok po ang mga hirit ninyo.....
    anyway, salamat po sa mga feedback ninyo....
    u give me d courage to try it in my engine....
    ty po...sirs ungas, bogart & otep...
    mangyan::: Kung bibigyan ka pa ng extra bottles don't hesitate to grab them... remember I have bigger engine block than yours, so I might need 2 bottles, hahaha!!! :mrgreen:
    These lube products are called "snake oils" by the established petroleum companies. I am not saying that this one is one of them.
    If I remember right this was the explanation - these lubricant enhancers may contain chlorine, which attaches itself instantly to surfaces. This will cause the oil to bind itself to the metal components of your engine - even if the oil is drained - a film or chlorine will remain coated on the metal. Much like after we swim in a chlorinated pool, our skin is coated with a white chalky film. Anyway this is good for the engine, BUT in time the chlorine will transform into an acid (hydrochloric?) which will eventually be harmful for your engine. I do not know if an engine flush or oil flush will help in between oil changes.
    If you have the resources and time - first do an oil flush using cheap oil. Put in your usual oil and add the additive. And after the lifetime of the oil have it analyzed by a lab.
    Feb 2018
    Quote Originally Posted by Freeman View Post
    Yes, There might be some additives that are "snake oil" but definitely not X-1R. I have been using X1R in my Porche since 2011 and found it to be really amazing. It gave my car extra power and better fuel economy. I was confident using it since I have checked that X-1R is Certified Space Technology and NASA Hall of Fame Awardee. I dont think NASA, being one of the world's best engineering organizations would certify "snake oil."
    Jan 2008
    XR1 MSDS listed chlorinated paraffin as one of its ingredient, same with Bardahl B1, but as they say, it only calls for shorter OC interval because they also contain metal deactivators or anticorrosion additives that neutralize acids, until they are depleted.
    But do we really need extreme pressure additives in our engines.
    Mar 2018
    Generally speaking, this X-1R engine treatment will not be of good use for newer, well maintained engines. Modern motor oils are already formulated with the right and advanced additives to meet different engine demands.
    On a personal note, I did try some engine treatments in the past on my preowned '89 Daihatsu Feroza like Duralube. Since I got my Feroza with significant mileage on its odometer, the engine response was not really good until I did major tune ups from spark plugs, high tension cables, carburetor, air filter and change oil. I did add Duralube (which is very similar with X-1R). I observed better engine response through time and cranking it was not a difficult thing to do. I guess X-1R will do work on older engines.
    Jan 2013
    I've been using X1R in my 2013 Innova vvti since 10k odo. Now its on 39k+ odo and no issues. Napansin ko lang na tahimik ang makina at pinong pino ang tunog lalo na pag high rpm na. Sarap ihataw. Minsan di ko napansin 100kph na pala kse ganda ng takbo.
    Sa 40k mag change oil na ulit ako at naka ready na ulit X1R.
    Btw, bago ko sinukan ito ni research ko muna ito at tumingin ng mga reviews at ang deciding factor ko ay yung NASA certified. Kung false ad ito cguro naman matagal na itong pinasara sa US.
    Mar 2003
    Sir Freeman,
    Thanks for your splendid explanation. Anyway, I'd already poured it into my engine. Haven't noticed any improvement....just the same....my engine is running smoothly.....
    Just hoping it is really non-hazardous and reduces engine wear....
    ser mangyan,
    any update with your experience with X-1R? bumili erpats ko eh.
    Mar 2003
    Sir Dakila7,
    Nothing much.... haven't noticed any difference....
    ang habol ko lang talaga ay engine protection....
    I am not expecting any increase in horsepower
    coz my ride is just 10 mos. old and has 11k in its
    odometer....perhaps, kapag medyo luma na ang
    sasakyan, mararamdaman mo ang increase sa
    engine power.....anyway it's worth a try........
    safe naman siguro....hanggang ngayon ok pa
    naman ang sasakyan ko......hindi pa sumasabog
    ang engine ko....hehehehe.......lagay mo na yan,
    sir... sayang yan...Php1000 ata yan....good luck.
    Apr 2005
    AFAIK... x-1r nalang ata ang available sa US MARKET na oil additives....
    nabasa ko sa FTC.GOV na wala na ang
    prolong, dura lube, slick 50 and motor up... na demanda ata sila for false ads.... napatunayan kasi na fake yung mga claims nila
    however... wala kang mababasa regarding X-1R which is a good thing... ibig sabihin di sila na dembanda ng Federal Trade Commission sa US...
    yan ang kagandahan sa US.. pag deceptive ang ads... sigurado ma demanda agad yan at maipasara.... dito kasi sa atin sa pinas.... try it for yourself lagi and ikaw na bahala... bale wala ang govt... di sila na action sa mga deceptive ads dito...
    KAYA GO FOR X-1R
    pls check the link
    http://www.ftc.gov/opa/2000/03/motor.htm
    Madami din namang deceptive ads sa U.S. [e.g. exercise machines that don't really work or don't live up to their claims, etc.]. It's just a matter of going through technicalities and loopholes.
    Dec 2003
    not sure if talagang effective and x1r, but ok benta nito sa amin hehe
    ganda ng commercial... www.x1r.com
    Certified Space Technology?
    Space Foundation/ NASA Space Technology Hall of Fame?
    magkano po ba yan?
    Hmm...
    Ang alam ko meron kami nito sa factory eh, hindi ko lang sure kung nagamit na. Hehe.
Anyone who tried X-1R engine treatment?
