Results 1 to 10 of 23
January 19th, 2006 10:24 AM #1
Ano ba ang best for fuel economy. Press the pedal steady or Press ON/OFF(bombahin) a Diesel Engine.
Sabi ng mekaniko pag diesel engine daw press ON/OFF the Pedal to continuosly inject diesel fuel. Any comment?
January 19th, 2006 10:29 AM #2
on and off siguro... kasi kung constant ang press mo sa gas pedal yung RPM ng engine mo tumataas din unlike paminsan minsan lang na apak. just my two cents.
January 19th, 2006 11:44 AM #3
sir acenie, a lot has been discussed already with regard to fuel economizing driving techniques...just search through the forums here...
IMO, as long as you have moderation in stepping on the gas, that's as fuel economizing as you can get...i don't think it's practical to step on/off the pedal, mangangawit ka lang. also watch your rpm (i think between 2k and 2.5k and efficient for diesels)Last edited by BeetOls; January 19th, 2006 at 11:56 AM.
January 19th, 2006 01:11 PM #4
Be steady and work through the gears... Stepping on and off the gas; can't see the logic why in an m/t unlike in an a/t where flicking your foot off the gas a bit helps upshift the tranny.
January 19th, 2006 09:58 PM #5
Dapat swabe ang paa mo sa diesel lalo na kung 4d56. Kapag binomba mo iyan, malulunod and magkakaron ng black smoke.
Hinay hinay lang sa arangkada. And maintain a constant speed.
January 20th, 2006 02:56 AM #6
baka naman mekaniko ng owner type jeep yan nagpayo sayo. yun dati owner jeep namin ganyan din turo sa kin. pero with mitsu diesel, parang gasoline ko din i-treat ang silinyador.
January 20th, 2006 08:46 AM #7
with modern drive by wire diesel engines (are D4D's drive by wire already?), there's no difference in how you step on the accelerator pedal. no matter how hard you step on it, it's still the ECU that will control the engine.
Signature
January 20th, 2006 08:53 AM #8
basta apakan mo til 2 to 2.5k rpm, enough na, constant lang yan and ull be ok na.
January 20th, 2006 10:12 AM #9
hehehe...just drive it the way you drive a gas engine...shift ka around 2,000 rpm or when you feel kaya na ng engine yun next gear. If you want power just downshift. Swabe ika nga sabi ni Mr. Swabe Otep. ;)
January 20th, 2006 01:37 PM #10
imo kung fuel efficiency, low rev means low fuel consumption therefore keep to a minimal but enough rev for each gear as much as possible, that way makakatipid talaga. case to case naman kung kailang bumirit.
the hybrid corolla cross looks more appealing at those prices.
Mitsubishi Xforce
