Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Or do I have to go get those commercially (Prestone etc.) available coolants? They come in different colors ano ba ok?
    Coolants have anti-rust and anti-boilover additives. Typically any will do. Just check how much water you have to mix with the coolant. Typical wuold be 50/50 mix but there are some that might require a different ratio.
    Dec 2007
    Meron ding variants which are ready to use (No water needed, pre-mixed na).
    But usually, I'd go for the concentratres, I think they give more bang for your buck.
    Concentrates? What's that?
    Just like concentrated juice drinks... mix it with water. You just don't drink the coolant mix.
    Or gargle with it Muka kasing mouth wash yung engine coolant eh
    buy Glycoshell from any Shell station
    add water
    just buy yun mga pre mixed na, para wala ng hassle pa mag mix ng water...
    Aug 2005
    Pure water is OK. But in the long run coolants are much better kasi the cooling system will be protected from rust, coolants has higer boiling point than water and they can "carry" more heat to cool the engine.
    Oct 2003
    make sure also na malinis ang radiator. otherwise, coolant will not be that effective.
    distilled water dapat
    Dec 2007
    Quote Originally Posted by jaymd View Post
    Yes, para minimum-to-none ang impurities/contaminants.
    Na-typo pala ako sa CONCENTRATES. :hammer:
    yung prestone na pre mixed 4 liters na sya nasa php380 lang sa truevalue, handyman at ace hardware.
    kabit and forget kapag coolant ang gamit mo
    but of course you still have to check it every morning if the coolant in the reservior is still at an acceptable level
    mas mabuti pa rin yung nagiingat
    pero sa experience ko di ako nag dagdag in 2 years
    never use tap water if your going to use a concentrate
    distilled dapat
    Mar 2005
    actually "coolants" decrease the heat carrying capacity of water but they are necessary due to the abovementioned effects
    pure water gives better performance
    Jan 2009
    Choose the type of coolant wisely. Best if you can get OEM coolants (pre-mixed or otherwise) from your respective casas that are suitable for your vehicle model, just to be sure. And never use tap water.
    http://www.search-autoparts.com/sear...27/article.pdf
    Dec 2007
    Quote Originally Posted by Psylocke View Post
    Really? How come various vehicles (in my experience, and others' too) would overheat sooner with pure water, versus water+coolant?
    ok di naman performance ng water
    kaso mas marami kasing benefits ang coolant
    may anti-rust at lubricating properties kasi siya at mas mataas ang boiling point so di siya agad mag-evaporate di tulad ng water
    protected din ang radiator natin so that it could stay clean and last longer
    ako i use castrol coolant concentrate and a 500ml anti rush concentrate + wilkins distilled water. and lastly i added up a bottle of Royal Purple Purple Ice coolant additive
    I recomend mag pa Lav'ra'mon muna kayo before adding coolants eetc for better performance.
    Jan 2009
    Quote Originally Posted by woohoo View Post
    I believe that the context of his reply is about the volume of additive vs water. Some people would think that if 50 parts additive and 50 parts water (50-50) is good, why not increase the additive volume to 70-30 so it can be better? This is of course not true. Water has better heat conductivity than the additive but suffers from a lower boiling point and is virtually defenseless against parts corrosion.
    That is the reason why concentrated additives must be mixed with water. The water does most of the cooling while the additive extends the water's capabilities to work under extreme conditions.
    If you have a mixed metal engine, e.g. aluminium head and cast iron block use coolant and water in a 50/50 mix. Check your manual as to which particular coolant to use, some car makers specify what type(not brand) to use.
    http://www.geocities.com/dtmcbride/h...ntifreeze.html
Engine coolant: Is water enough?
