i doubt any engine will run at this ignition timing, not even the computer controlled ignition. some ignition system go as high as 36 degrees at higher revs. when you check igniton timing, it is set at idle speed with electronic spark advance disabled or both the vacuum and centrifugal advance disabled.please check again.
iba pala nasabi ko hehe
