Results 1 to 16 of 16
    Feb 2009
    Quote Originally Posted by sotel View Post
    iba pala nasabi ko hehe
    you might have been talking about ignition points dwell angle. 360 degrees divided by number of cylinders multiplied by 60% +/- 2 degrees
    Feb 2012
    ah un nga sir heheh
    Jan 2011
    i used to have this engine on my owner jeep before. bulletproof engine, as in matibay. medyo advanced ang timing ko dito, 10 BTDC. ang valve clearance ko, parehas lang ang i/e at 8. ang jet ko naman 80/95. hope this helps.
    Nov 2006
    Quote Originally Posted by shelu View Post
    sir salamat po inputs... bakit ganun di kaya yung 80 primary jet ko... hanggang 100 lang.. pag binabaan ko pa humahatching na xa yung parang napuputol ang andar pag apak ko sa gas...
    Jan 2011
    Quote Originally Posted by exoskeleton View Post
    kaya pa pababaan yan hanggang 80. hanapin mo yong A/F screw. bali adjustment lang ng hangin at fuel ang kailangan para makatakbo ng maayos. normal lang pag sakal na alalay sa selindayor para di mamatay. kapusin talaga ng fuel pag start up, kaya alalayan mo ang makina. regarding timing light, may instruction naman sa manual nyan. kung wala, google mo. sa uno mo dapat ilagay ang malaking clip ng timing light. hope this helps.
    Jan 2011
    Nov 2006
    thanks sa link sir... yes i also watched that video using a timing light and unfortunately i dont have one, .. so i just prefer the vid posted above. I think i know whats the problem why it wont light on my tester screw driver, i cant find the breaker point or they call it contact point, it was already converted to electronic igniter so i dont have the contact point anymore... :D .. they said it is better than the contact point thing well in terms of durability.
    so sad im too excited when i got my tester screw driver from a store to perform the procedure..
    Nov 2006
    sir i tried this procedure on my 4k engine yesterday... bakit po ayw umilaw ng test light ko.. naka ON ang power, peo ayw pa rin umilaw kahit anong ikot ko sa pulley ng crankshaft.. magkaiba ba wiring sa VW sa video at sa 4k engine? kasi sa video naka attached yung wire ng test light nya sa negative nung ano ba tawag don igniter? tama po ba? tapos nakaground naman sa body / engine yung tip ng tester, peo wala nangyari po... ikot ko na pulley wala nangyari, ikot ko yung advancer, paulit-ulit peo wala tlga umilaw eh.
    ask ko na rin po... pag advance timing ba 4k engine ba eclockwise ang ikot ng advancer or counterclockwise?
4k engine valve clearance, idle speed, ignition timing
