Results 1 to 10 of 12
June 7th, 2008 01:49 PM #1
Guys,
tanong ko lang po kung pwede pa po ba gamitin yung air filter na nadeformed kasi habang nililinisan ko yung filter at tinataktak bigla ko naihagis na deformed ng konti, pero kasya pa siya dun sa casing. masama po ba kung gagamitin pa ulit ito? o mas advisable kung palit na lang.?
thanks..
June 7th, 2008 02:23 PM #4
sir bilog ba yan?
IMO wag mo nang isugal yan .. palit kanalang po ng bago ..
June 7th, 2008 02:28 PM #5
it's you who can answer that. do you think the damage is not too great that air can leak bypassing the filter? did the paper break or deformed making it bypassable?
June 7th, 2008 02:43 PM #6
June 7th, 2008 02:46 PM #7
- Sep 2006
- 1,335
June 8th, 2008 02:06 PM #8Replace na.
As Rion wisely suggested, it may not be filtering properly as air might be bypassing through the deformed casing.
It may also do more damage if the filter media disintigrates and is sucked into your engine.
With the high cost of diesel, your fuel consumption may improve with a new air filter.
June 8th, 2008 04:06 PM #9
teka, wrong grammar ata nasabi ko.:lolabove:
diesel dude is mocking me. :hysterical:
dapat "the damage is not too great that air still can't leak bypassing the filter?
my goodness, when will i ever use the words right...
anyways bro, for peace of mind, palitan mo lang yan ng bago. baka may hidden damage yan. when did you last changed airfilter anyway?
- Sep 2006
- 1,335
June 8th, 2008 09:52 PM #10Hi Rion,
Hindi naman importante ang english grammar sa posts natin dahil pinoy tayo. Ang mahalaga ay naiintindihan ang mensaje natin para makatulong tayo sa mga kasama. Mas komportable lang ako sa ingles.
Fyi, your message came in clear. You are among one of the guys I admire for sharing valuable technical information, as well as your thoughts to fellow tsikoters.
So, more power to you.
Godbless,
Diesedude
In our case, the thermostat was removed. But yes, if the thermostat is stuck open, it might show...
low idling during cold start
