Results 1 to 12 of 12
    Nov 2007
    Guys,
    tanong ko lang po kung pwede pa po ba gamitin yung air filter na nadeformed kasi habang nililinisan ko yung filter at tinataktak bigla ko naihagis na deformed ng konti, pero kasya pa siya dun sa casing. masama po ba kung gagamitin pa ulit ito? o mas advisable kung palit na lang.?
    thanks..
    stock paper filter po ba? anong sasakyan po?
    Nov 2007
    stock paper filter po. denso, toyota revo po, 2L engine.
    sir bilog ba yan?
    IMO wag mo nang isugal yan .. palit kanalang po ng bago ..
    it's you who can answer that. do you think the damage is not too great that air can leak bypassing the filter? did the paper break or deformed making it bypassable?
    Nov 2007
    Quote Originally Posted by s_quilicot View Post
    sir bilog ba yan?
    aus lang po ba kahit gamitin ko muna siya for a while para mkabili ng new one? 7km nearest toyota dealer po dito..
    Nov 2007
    Quote Originally Posted by rion View Post
    di naman po masyado malaki ang damage, yung paper filters po na deformed lang pati yung aluminum screen.. naging curves instead of straight lines.
    Sep 2006
    Replace na.
    As Rion wisely suggested, it may not be filtering properly as air might be bypassing through the deformed casing.
    It may also do more damage if the filter media disintigrates and is sucked into your engine.
    With the high cost of diesel, your fuel consumption may improve with a new air filter.
    teka, wrong grammar ata nasabi ko.:lolabove:
    diesel dude is mocking me. :hysterical:
    dapat "the damage is not too great that air still can't leak bypassing the filter?
    my goodness, when will i ever use the words right...
    anyways bro, for peace of mind, palitan mo lang yan ng bago. baka may hidden damage yan. when did you last changed airfilter anyway?
    Sep 2006
    Hi Rion,
    Hindi naman importante ang english grammar sa posts natin dahil pinoy tayo. Ang mahalaga ay naiintindihan ang mensaje natin para makatulong tayo sa mga kasama. Mas komportable lang ako sa ingles.
    Fyi, your message came in clear. You are among one of the guys I admire for sharing valuable technical information, as well as your thoughts to fellow tsikoters.
    So, more power to you.
    Godbless,
    Diesedude
    May 2007
    Quote Originally Posted by iRevoLution_mo View Post
    Guys,
    thanks..
    Only you can answer that. If your judement is wrong, cause money and time. Etheir way, magpapalit karin why not now.
    * DD: alam ko naman po you mean well. hehe...
    salamat po, I appreciate your thoughts. same here, infact double po respeto ko sa inyo. you are one of the elite members here that I learned from, so much.
Air Filter na deformed.help po.
