Results 11 to 19 of 19
- Jan 2008
- 4,726
May 2nd, 2014 10:19 AM #11hindi left side dyan sa last pic mo (same engine ba yung first and second pic?).. yung nasa alternator malapit oil pressure sending unit yun..
dun sa first pic yung malapit sa glow plugs ang para sa heater control, yung nakatutok sa radiator hose ang temp gauge sensor
- Apr 2007
- 487
May 3rd, 2014 01:11 PM #12Sinubukan ko hugutin yung plug connecting dun sa second pic, wala namang reaction sa temp gauge ko. Ang napansin ko lang, hindi nageengage yung compressor ng AC pag nakabunot yun. Sinubukan ko rin tanggalin yung connection sa instrument panel (2 set ng connectors). Pag yung left side connector lang ang nakakabit, pumapalo hanggang taas (lagpas sa level ng HOT) yung needle, meaning hindi sira yung gauge ko, tama ba?
May 5th, 2014 09:53 PM #13
kagulat nabuhay uli ang thread ko.
btw, i figured out yung query ko dito sa thread ko. it's a cut-off switch sa airconditioning system once na magoverheat na coolant. above 108 deg celsius ang cut-off nya accdg to pdf files na nakuha ko sa internet.
with regards sa query ni boy37, either cut-off switch din yan sa A/C system (shut-off nya A/C in other words beyond its set temp reading) or electric cooling fan switch iyan.
sa tulong ng multitester in the ohms range, cut-off yan kung zero ohms (cold) at increasing resistance habang painit ang coolant. fan switch yan kung high resistance when cold tapos decreasing ang resistance habang painit ang coolant.
yung temperature sensor nung sakin ay yung letter "A" sa pic mo. double contanct din.
- Dec 2017
- 55
May 18th, 2018 02:32 PM #14
i have a mitsubishi l300 and temp gauge doesnt work at all. can somebody review my photo?
- Mar 2016
- 22
October 13th, 2018 12:01 AM #15
- Dec 2023
- 2
December 21st, 2023 12:54 AM #16Pasensya na binuhay ko tong thread.
Yung L200 1998 ko kasi ayaw mag engage ng compressor at walang lamig ang aircon.
Hindi rin tumataas yung menor pag pinindot ko yung AC ON button.
Pag sira ba tong temperature sender sa 4D56 hindi din gagana yung idle up or mag engage yung sa compressor?
Sabi kasi ng mekaniko need daw new compressor, sabi ng isa shaft seal daw. Nag basa ako at check sa youtube and nakita ko na
may mga video na temperature sending unit daw muna tingnan. Kasi daw if sira di daw gagana yung compressor at yung menor. Totoo ba?
Paano nyo na fix yung sa inyu?
- 54,215
December 21st, 2023 01:03 AM #17
- Dec 2023
- 2
December 21st, 2023 01:42 AM #18BTW. The story pala is that while I left the car idle for around 20 minutes naka ON ang AC pagbalik ko I heard sa soft leaking sound and a sudden soft blow (parang gulong ng kotse na leak)
and may nakita ako usok sa hood. Pinatay ko agad yung engine then upon opening sa hood wala na ako makita na umuusok. Kinabahan ako kasi akala ko baka nag overheat yung engine ko.
After a while pag ON ko nag start naman yung makina and that is the time napansin ko wala ng lamig yung AC tapos yung compressor din di na umiikot.
Hirap kasi maghanap dito sa area ko ng magaling mag diagnose or mag ayos.
- 54,215
December 21st, 2023 07:51 AM #19
Thanks for your replies. Sa July rehistro ng car, so sabay ko na lang dun pag transfer? Or better...
transfer of ownership / registration cost
