One day, bigla na lang nasira yung high beam sa left side ng headlights ko (stock Osram bulb - 50W/60). Dinala ko siya sa isang shop sa Abad Santos St. at sabi ng owner na pundido na raw ang bulb, without checking the wiring.
He added that there's no need to check the wiring because both high beam would malfunction if there's a problem with the wiring. So I believed him and replace both bulbs for P350 each. The brand I think is Zip (80W/100). Nirecommend niya na taasan na lang para mas malinaw. Tinanong ko kung hindi ba siya mag-oovercharge at sabi niya hindi naman daw.
Ito yung sumunod na sequence after kong magpalit ng bulbs:
(Day 0-7) = Okay pa naman both bulbs. Pero medyo hindi ako satisfied sa brightness at nakaka-experience na ako ng hard starting.
(Day 8) = Nawala ulit yung high beam ng left side.
(Day 9-11 ) = Bumalik yung high beam ng left side. (Everything's okay)
(Day 12-18) = Nawala yung high beam at low beam ng left side.
(Day 18-19) = Nawala yung high beam ng right side. Pero gumagana ulit ang high at low ng left.
(Day 20-21) = Bumalik yung high ng right.
Ngayon, ang gumagana lang sa akin ay high-low ng left at high ng right. Ano kaya ang problema nito? Pwede bang mag-overcharge yung battery sa nilagay nilang bulbs?
Can you recommend any good auto electrician within Makati area?
