Results 1 to 13 of 13
    I had my front break pads replaced 2 days ago, just this night I observed my right breaklight are still on even engine is shutdown and key is turned off...what could be the possible wiring problem, i did not want my battery to be drained so I pulled the fuse and leave the car at home, I work at night. Thanks for your inputs....
    Jan 2008
    Check if left side brake bulb is busted(filament), if yes there's a possibility that your brake switch(located above brake pedal-lever) was jammed.
    most probable cause is the brake light switch shorted out
    Sep 2004
    Malamang nadurog na yang parang grommet sa taas ng brake pedal. You can buy one sa auto shop, pwede DIY yan, less than P50 lang each.
    Quote Originally Posted by Galactus View Post
    ganyan din nangyari sa akin.
    yes, break pedal switch check first and WD40 is your remedy. moisture and rust are the most common source. my guess
    do you mean isang side lang ang nakailaw? so hindi brake switch ang problem pag yung isa lang ang nakailaw. electrical problem sa wire, bulb or sa lamp assembly malamang.
    Tama ka sir, yun nga ang nangyari, kaya lang di pa ko nakakabili, pero ang remedy ko bolt and nut na kasya doon sa hole. Nadiscover ko to nung umaaga na, kasi na observed ko maraming plastic particle sa floor matting ko...Anyway, thanks at natutu na naman ako sa inyo...Have a good day...
    Oct 2008
    sir try nyo po pa adjust yung pedal height ng brake pedal po.. or yung sa switch ny need lang adjust tnx...
    Nov 2003
    yeah, it's the brake pedal switch. nothing to do with the pads being replaced naman... just replace the plastic/rubber portion and it should be ok.
    May 2004
    happened to me before. the electrician replaced the rubber using old slipper and adhesive.
    also happened to me before.
    I fixed mine using a peso coin and a double sided tape.
    Nov 2003
    excellent diy fixes!
Break light still on
