Originally Posted by
v6dreamer
Your speedometer is run electrically (do not mean digital) and you just replace the cable.
You have to measure the signal, you need to hook and auto meter to the wire and check for AC VOLTAGE. It will be small and goes up and down with the speed of the vehicle. A good square wave on a scope. Check all the connection again.
The main Integrated Chip on the speedometers circuit board has probably gone bad.This causes erratic or no operation of the speedometer/odometer.
If this is the case, there is no way to repair the problem.You must get a new or used speedometer !
