Results 1 to 9 of 9
October 21st, 2008 12:05 PM #1
Guys,
I have a 3 door pajero which I recently changed the speedometer cable because it broke.
the problem is just two weeks of driving and I have over 4000 kilometers in the Odometer, it turns too fast.
has anyone experienced this? If so can anyone give an advise on what to do?
TIA
October 29th, 2008 04:42 AM #3
Your speedometer is run electrically (do not mean digital) and you just replace the cable.
You have to measure the signal, you need to hook and auto meter to the wire and check for AC VOLTAGE. It will be small and goes up and down with the speed of the vehicle. A good square wave on a scope. Check all the connection again.
The main Integrated Chip on the speedometers circuit board has probably gone bad.This causes erratic or no operation of the speedometer/odometer.
If this is the case, there is no way to repair the problem.You must get a new or used speedometer !
October 29th, 2008 01:06 PM #4
It may be evil to say this... but disconnect the sensor from the transmission, for the meantime.
Are you sure it's just the cable you replaced? And if so, was it reconnected properly?
October 30th, 2008 12:03 PM #5
thank you sir for the input, the mechanic replaced the cable since it was already twisted cut.
and when it was replaced the speedometer and odometer immediately functioned. but I did not noticed it was out of synch until after a week since the reading was really absurd.
October 30th, 2008 12:46 PM #6
November 19th, 2008 03:18 PM #7
mga sirs, had my ride checked at an auto electrical shop and they electrician told me that "tumatalon " daw ung speedometer and I had to replace it na daw.
this after just taking a glance at it and me explaining the problem to him and not much inspection on his part.
do I really have to change the speedometer or is there any other way to fix the problem?
THE AUTO SPECIALIST
- Mar 2006
- 607
November 19th, 2008 11:38 PM #8obd2 system na ba ang ride mo ?
if yes , go to a shop with scanner and compare the readings from the scanner to your speedometer
Looks like TGPH silently edited the article and removed the entry for Velocita Motors/Ferrari.
Car Sales Data (2024)
