Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 70
    Sep 2012
    #21
    It makes it irrelevant kung malipis na yung carbon brushes nya sa loob ng starter... sila na rin mag suggest sa iyo na palitan pati solenoid para isang baklasan na lang pwede rin naman nila i test yan via battery lang kung mag crank properly bago ikabit
    ito yung itsura ng carbon brush na usual na unang nasisira sa loob ng starter
    Last edited by jodski; December 20th, 2013 at 05:39 PM. Reason: Added more details
    Aug 2013
    #22
    Salamat sa mga info guys! Really helpful! Will bring the ride to the mechanic tom.
    Sent from my H100 using Tsikot Car Forums mobile app
    Sep 2011
    #23
    Quote Originally Posted by zacks_888 View Post
    If I remember sbi ng shop na nag offer ng overhaul is ung carbon o magnet ata is upod na. But after ko sa Rey's ok na. Hindi na sya nag playa kahit once. Check mo rin pla ung battery terminal mo bka maluwag lang din
    Sir tanong ko lang saan sa marikina yung shop ni rey?
    #24
    some cars have the electricity running from the battery to the key to the starter solenoid.. it's a long route that offers more resistance to the flow of electricity... when the battery gets a little weak, there isn't enough electricity to activate the solenoid..
    to alleviate this, some cars use relays that effectively shorten the route the electricity has to travel to the solenoid, thus cutting down on resistance. these cars then start better..
    what your mechanic is suggesting, is to put in a relay and minimize the resistance due to long cables..
    Aug 2013
    #25
    Advice taken Dr. D! Will bring it to talyer on Dec 26 pa. The mechanic is suggesting either the carbon brush and starter solenoid. I might give it a go. I'm thinking kasi na pag pinalagyan ko muna ng relay tapos may tama rin pala yung solenoid at carbon brush eh baka bale wala rin.
    I wanna ask narin, are there any cons of adding relay to the system?
    I think I have problem with my servo din but I'll post it on a new thread.
    Merry xmas guys!
    Aug 2013
    #26
    Just as update guys:
    Had may starter fixed na. Bale carbon brush and diode lang ng solenoid lang yung pinalitan.The rest in good condish pa.
    Now it's working fine, one click start.
    Just an observation though, compared to my other ride (which is a rav4 2005)... napansin ko lang na may millisecond delay before it starts... as in konting-konti lang. With my rav4 kasi sobrang real-time nung kabit ng kuryente, pero with the galant parang nagblink muna ng isang beses yung mata mo before it connects.
    ...dito na ba pumapasok ang relay? Just curious hehe
    #27
    ^ Ground connections tend to weaken as the vehicle age. Worth checking the grounding or better yet install additional grounding wires.
    Aug 2013
    #28
    Added an hks grounding kit kanina. May lights have never been brighter!
    Aug 2013
    #29
    Maybe a relay din soon. Pero the starter's working just as fine now.
    Oct 2013
    #30
    Quote Originally Posted by mark1985 View Post
    How much ang hks grounding kit?
    Sent from my LG-D802 using Tsikot Forums Mobile App mobile app
    Beep Beep! School Bus! Beep Beep! School Bus!
    Aug 2013
    #31
    850 php kuha ko bro.
    Sent from my H100 using Tsikot Forums Mobile App mobile app
    Jul 2010
    #32
    Since bagong palit yun carbon brush ay possible hindi pa masyado sayad yun carbon brush sa commutator. Kaya medyo low current pa ang supply sa commutator. Sana nalinisan na rin yun surface ng commutator contacts.
    Aug 2013
    #33
    I see. Yung commutator contacts yan ang diko sure.hehe although nung binantayan ko nilinisan naman nung mekaniko.hehe
    May 2013
    #34
    Hi!
    Magtatanong lang din sana regarding starter/alternator/battery since related naman yung topic sa thread na 'to sa concern ko.
    The car is Honda City 1998 model. The past month ang hirap i-start nung kotse. Eto yung nangyayari:
    1. Pag-start ko ng kotse, magcra-crank pero di tutuloy sa pag-start ng engine. Eventually (after 2-3 tries), hindi na magcra-crank, magiging clicking sound nalang naririnig ko.
    2. Susubukan kong i-jump start and then aandar na siya kapag na-jump start.
    3. For the next 2-3 weeks wala akong problema sa pag-start ng kotse. One turn lang ng key, aandar na ang engine.
    4. After some time (mga 2-3 weeks), mahihirapan nanaman ako i-start yung kotse so susubukan ko nanaman i-jump start yung kotse and then magiging ok nanaman for some time yung pag-start ng kotse.
    5. Kanina ayaw nanaman mag-start at clicking sound lang naririnig ko nung pinipihit ko na yung susi. Napansin ko rin kanina, parang humihina yung lights dun sa dashboard display. Pati yung clock nung car parang humihina rin ang pag-ilaw.
    Notes:
    1. Pina-check ko na twice yung battery sa motolite and twice sinabi saken na in good condition pa yung battery ( less than 3 years palang yung battery)
    2. Mahigpit na yung terminals sa battery and malinis naman yun
    Questions:
    1. Starter ba or alternator ang problem?
    2. May estimate ba kayo sa cost ng pagpalit ng starter or alternator?
    2. Saan ba may matinong auto electrical shop dito sa Makati? Mga 3-4 electrical shops na kasi napuntahan ko rito sa Makati at aircon at radiator lang usually ang ginagawa nila. Walang makapag-diagnose confidently when it comes to wiring or alternator or starter problems.
    Salamat po ng marami in advance!
    #35
    Based sa mga sinabi ninyo sir, nawawalan ng karga yun battery ninyo. Gaano na po ba exactly katagal yun battery ninyo? Most probably kasi, battery ang problema ninyo at hindi alternator, dahil nakakargahan naman nang maayos ang battery ninyo. Rule out na ninyo ang starter since wala naman po siyang kinalaman sa paghina ng mga ilaw. Ang role lang naman ng starter eh i-crank ang engine para tumakbo.
    May 2013
    #36
    Thanks testament11!
    Mga 2 years and 9 months na yung Motolite battery ko. Possible po bang magkaproblema pa rin yung battery kahit na-diagnose na twice ng Motolite na ok pa naman yung battery?
    Thanks!
    Aug 2013
    #37
    Since nacheck na ung battery at sabi ok pa daw, possible rin na baka may ground sya somewhere na dumidiskarga ng bahagya sa battery. San ka sa makati bro, makati based din ako pero i bring it to jemson's sa banawe to have my electricals fixed. Maayos sila gumawa.
    Aug 2013
    #38
    *based din sa makati
    #39
    Quote Originally Posted by CaloyL View Post
    Thanks testament11!
    Thanks!
    I agree with testament 11 with this.
    di na nagho hold ng charge yung battery, considering that your battery is almost 3 years...
    Jul 2010
    #40
    Hi!
    Notes:
    Questions:
    Kaya humina yun Battery ay dahil sa ka trigger sa starter solenoid at di pag ikot ng starter. Pa overhaul mo Starter mo para malinisan yun commutator at palitan na rin yun carbon brush kung pudpod na. P350 ang labor charge ng overhaul. Pwera parts.
not battery or alternator daw, starter problem kaya?
