Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 70
    Aug 2013
    #41
    Tapos pagpalit ng starter, add relay pa! Ahahay! :D
    Sent from my H100 using Tsikot Forums Mobile App mobile app
    #42
    your battery is slowly dying.
    the fact that you can start the car by connecting it to another, presumably stronger, battery, is proof of this.
    you can keep doing this for a few weeks more, or you can save yourself the trouble by replacing that battery now.
    and for all you know, your car already has that relay!
    we were push-starting our cars many years ago, because we "refused" to buy a new battery. we were students than; money was hard to come by, and we refused to ask funds from our parents. we saved up for it.
    May 2013
    #43
    Salamat po sa mga reply niyo mark1985, Flipo, at Chinoi!
    Based sa mga replies pwedeng battery or starter or loose wirings/connection ang problem.
    May marerecommend ba kayong shop dito sa Makati na pwedeng i-check ang mga yan at ma-diagnose ang problem? Malapit lang ako sa may Chino Roces & Dela Rosa Avenue. Pwede rin naman sa Banawe ko dalin pero kung meron namang shop dito sa Makati edi better kasi mas malapit lang at para kung magka-problema ulit or may backjob madali ko lang mababalik sa shop.
    Salamat ulit ng marami in advance!
    May 2013
    #44
    Thanks for the advice dr.d! Ang iniisip ko kasi before dahil sinabi ng Motolite na okay pa yung battery ko (siguro about a month ago yung last na pa-check ko) baka hindi rin ma-address ang issue kung papalitan ko kaagad ang battery. Anyway, salamat sa suggestions. Ipapa-check ko nalang din ang starter just to be sure then palit ng battery.
    #45
    Quote Originally Posted by CaloyL View Post
    well, another possibility is you have an on-and-off, intermittent solenoid. that should be easy to fix.. replace it.
    May 2013
    #46
    Thanks dr. d! Will have it checked tomorrow. I already found an electrical shop here in Makati. Will let you guys know the result and if the service is ok.
    Thanks!
    May 2009
    #47
    Mga 2 years and 9 months na yung Motolite battery ko.
    Candidate for replacement na yan. ganyan sintomas ng bateryang malapit nang madedbol. yung motolite gold ko nagsisimula na rin maginarte after 2 years and a few days. ipon mode na for new battery.
    May 2013
    #48
    Ok na, battery nga talaga yung dapat palitan. Nagpunta ako sa 2 Motolite shops (different shop 'to sa pinuntahan ko a month ago) and parehas na chineck at dapat na raw palitan. Mali yung pag-diagnose nung Motolite na pinuntahan ko a month ago, sabi kasi dun ok pa raw yung battery kahit nag-jumpstart na ako para ma-start yung car. So, yun, bumili na ako ng battery kanina.
    Thanks for the inputs guys!
    May 2013
    #49
    Quote Originally Posted by miked View Post
    Yup. Ayun, pinalitan ko na ang battery kaysa ma-hassle pa ako. Thanks miked!
    #50
    Hello Sirs/ Madam, same problem with me pag start ko ng car minsan it wont start on the second try it will start naman. So I decided to bring it to casa to have check, and I also let them check my fog lamp kasi according to their previous check di naman pundido yung fog lamp, rather it has something to do with the wiring. But unfortunately, di nila naayos yung fog lamp kasi modified daw and they need 2 days to have it fix. Same thing with the starting of my car which according need to replace na yung starter assy., but wala sila stock ng part (sabi nila surplus na lang daw).
    Pag kalabas ng casa napansin ko na pag nag-full break ko feeling ko parang mamatay yung makina pero di naman namamatay. But on the 2nd day nung nag full break ako kasi mag u-turn ako bigla siyang namatay sa pag full break, pero nagstart naman. Ganon pa ren minsan sa unang start di siya nag start minsan nagstart naman, until on the sixth day start ko siya, nagstart naman then bigla namatay nakailang ganun. So after 15 mins. start ko nagstart then okay na di siya namatay, linabas ko siya sa garahe pero meron na ako naramdaman na parang mamatay siya, then after ng pag bwelta ko namatay nga siya, bumalik nanaman sa start then biglang namatay, so iniwan ko nanaman after 30 mins. okay nanaman inatras ko pa para igarahe na lang. After mga 5 hours pag uwi ko ng bahay start ko uli okay naman nagstart and di siya namamatay inatras at abante ko siya ng ilang beses di naman siya namamatay.
    Ano kaya problema nito sa wiring or sa starter assy as what the personnel sa casa told me?
    (I just bought my battery December 2012)
    Oct 2011
    #51
    kung start patay lagi sasakyan mo sir baka naman may ibang problema na yan at hindi na baterya o alternator. pag palyado ang baterya o alternator patay na lagi yan sir.
    #52
    According sa casa need replacement sa starter assy. but naghahanap sila ng parts kasi wala sila stock. Nangyare lang yung start then biglang namatay after pagkalabas ng casa. as of this time 11:39 PM 28 Feb. 2014 nagstart naman siya and di namamatay, weird nga pero nakakatakot paren gamitin kung malayuan ang byahe. Di kaya sa wiring? Kasi if mapalitan nga yung starter assy. if sa wiring pala problema ganun pa ren.
    Jun 2004
    #53
    Kung starter pa check mo sa electrical/starter repair shop, mura lang yan. Last time nagpaayos ako ng starter mga 1k nagastos ko lahat lahat.
    The starter motor is only there to start the car, if it shuts off while running then the problem is something else. I would replace the fuel filter if not done within the past 2 years and check fuel pump/fuel pressure.
    Jun 2004
    #54
    Anong car pala yan? madami pa kasi ibang possible things to check. Check mo rin mga ground wires, baka may loose wiring. Check mo rin na walang vacuum leaks at ok braking system.
    #55
    Quote Originally Posted by chris_d View Post
    GSR 2001. dinala ko sa casa ang problema is pag start ko di siya agad ng start minsan kailangan ng 2nd try, sometimes start naman agad. Pero nung pagkalabas ng casa doon pumasok yung pagka-start bigla siyang namamatay it happened earlier pero nagstart din naman after 30 mins. kaya naipasok ko sa garahe. start ko uli mga 5:30 pm nagstart 1click then di siya namamatay inandaar ko atras abante okay naman di ko naramdaman yung feeling na pag nagbreak ka feeling mo mamatay makina. I'm really wondering what is the problem.
    #56
    Quote Originally Posted by dged View Post
    my experience with casa: no repair, only replace.
    in your instance, i feel your starter is not the problem. if it were, your engine wouldn't even turn over..
    hindi kaya contaminated fuel yan?
    #57
    I don't know Sir, how would you know na contaminated fuel?
    would it be a loosed wiring?
    #58
    Before ko ipasok sa casa my only concern is pag start ko di siya nagstart agad rather it will start on the second try.
    After ko ipasok ng casa doon na pumasok yung magstart siya then biglaang mamatay and yung feeling na pag nag-full break feeling ko mamamatay yung makina. Di kaya may nagalawa sila na wiring kasi sabi ko ayusin nila yung wiring ng fog lamp kasi according sa in charge ok pa naman yung fog lamp hindi pundido sa wiring lang may problema. According to them modified daw yung wiring ng fog lamp they need 2days to fix it. Yun lang naman pinagawa ko sa casa check wiring ng fog lamp which they did kasi sabi nila modified daw, second yung starter assy daw need replacement na then nag engne wash sila. Baka may nagalaw silang wire sa pag check nila ng wiring ng fog lamp kasi nag occur lang naman yung start then biglang mamatay pagkalabas ng casa before ko ipasok it was never my concern.
    Aug 2013
    #59
    Naku baka may nagalaw sila dun. San ka located bro? I know a place who's very good. Although may pagkapricey sila, they have a very good electrician.
    Feb 2014
    #60
    I have the same issue. Hot starting. pag nag park ako saglit patay makina. mahihirapan nko i start. mag antay muna ako mga 5 minutes bago sya mag start ulit.walang redondo. mga 5 times na ngyayari. Possible starter issue din kaya? Thanks
not battery or alternator daw, starter problem kaya?
