Results 1 to 10 of 14
    Jan 2011
    imho, there is nothing wrong with the alternator. walang kinalaman yan sa nginig. palagay ko, sira ang aircon actuator mo. kindly check your actuator. bali dalawa po yan, its either of the 2 ang maaring sira. isa po nyan, nasa throttle body area (carb/efi), vacuum selonoid po yon sir. hihilain paatas ang rpm pag naka engage ang aircon. ang isa non, yong aircon actuator na connected sa compressor ng sasakyan natin. hope this helps. pwede po ninyo i DIY yon.
    Dec 2013
    tumataas naman po yung idle ko pag naka on ang a/c, pero will still check on this, salamat
    Dec 2013
    900 no a/c, 1000 with a/c... anything below 900 nanginginig na makina kaya di ko na binabaan
    Quote Originally Posted by James Baviera View Post
    ibig mong sabihin, tinaas mo ang idling speed mo dahil nanginginig nga siya?
    if your idle up is working, you wouldn't have to tinker with your idling rpm setting.
    rpm drops when braking? sounds like your idle air bleed screw is too tight. this might also be the reason for the nginig.. open her up by 1/2 to 3/4 turn counterclockwise.. but if there is no improvement, ibalik mo sa original setting, para isa-isa mong ma-shoot the trouble..
    Dec 2013
    saan po nakikita eto sa 2e?
    Feb 2014
    ganito po ang problem ko e, bumababa ang rpm pag umapak ng brake.. noticeable sya pag ung tipong stop and go ang traffic at nakaalalay sa brake kc AT po ung oto. paano po ba iadjust un? kasi po sa dami ng mechanic na napagsabihan ko ng prob ko, ni isa sa kanila wlang naka resolve.. kesyo bka engine support daw, pero pag check ng engine support buo naman. so after that, wla na silang ibang maisip.
    Feb 2014
    dr.d, ask ko lng po kung nagse-service kayo? ipatono ko sana ang auto ko sau, prang wala kasi sa tono. i have lot of issues on idling
ngninig engine when all accesories on
