Results 1 to 15 of 15
    Dec 2009
    yung car ko honda civic vtec 3 2002 model. hindi kasi gumagana ung low beam nya. pg high beam ok nmn. tnry ko na i tap directly s baterya to check kung ok pa ung bulbs. ok p nmn. bigla nalang kasi nawala yun habang ngdrive ako. ano kaya most probable cause non? and san kya recommended shops na kaya gawin un. ngtry kasi ako sa banawe ang gusto e irewire n agad, tapos palitan ko dw ng mas mataas n wattage ng bulb. pag mas mataas dw kasi wattage hindi daw kayanin ng stock n wiring. masusunog lng daw un. padvise nmn. thanks.
    Baka naman pinalitan mo na lowbeam HL mo tas di mo napalitan yung wiring mo at nasunog ?
    Totoo sinabi sayo, pag mas mataas wattage at stock pa rin yung wiring mo. Sunog talaga yan
    Dec 2009
    hindi pa ko nagpalit ng HL. basta bigla nalang nawala un habang nagdrive ako. medyo ang hirap nga mgbyahe sa gabi kasi high beam lang pwde. hassle sa mga kasalubong na sasakyan. ano kya possible reason and san maganda ipacheck and pagawa?
    Sa auto electrical shop mo dalin mas kabisado nila tungkol sa lighting system ng sasakyan at wiring nito .Madali nila ma trace kung bakit ayaw gumana iyong low beam mo.
    Sep 2009
    Original bulbs since 2002?
    Mostlikely it is a busted bulb, one of the filaments may have been busted due to normal wear and tear, lalo na if you run on low beams all the time like I do. Buy a new set.
    Dec 2009
    Quote Originally Posted by tanatej View Post
    ok pa yung bulbs. nagconncect kasi kami directly sa battery. gumagana naman.
    Aug 2006
    check your relay for your head light... baka defective na...
    Tama ung isa, check your relay kung gumagana or baka ung terminal.
    Feb 2009
    Quote Originally Posted by jeromealbert_08 View Post
    jeromealbert,
    your headlight system uses one headlight relay for the LH and one relay for the RH side. they both share the same grounding point G401. if the headlight works on high beam, it means the relays are okay and the ground 401 is okay. the problem lies in the combination switch. if you have the patience and tenacity to take it out of the car and clean the contacts, 99% of the time the low beam problem is solved.
    jick
    Feb 2009
    jeromealbert,
    jick
    on that missing 1%, try grounding the wire on terminal 6 of the combination switch. the wire insulation color is red with white tracer. if the low beam works this way, now you have completed the diagnosis procedure and found the combination switch the culprit
    jick
    Oct 2009
    bring it to reys electrical baka makatulong.
    Did you shake the bulb when you tried it directly to the battery?
    Did you check the terminals and sockets of the bulb?
    Feb 2009
    jick
    why do people guess when they are already given the facts and instruction what to look for and what to do? guess and hope process when you have a definite anwer?
    Dec 2009
    Dinala ko na sa banawe and found out that the column switch is broken. Saan kaya mura makakabili (brandnew or surplus) non? Tnx.
    Feb 2009
    most problems with this steering mounted combination switch are burned or pitted contacts which can be cleaned or filed or sanded with a 240 grit sandpaper
Low Beam not working
