Results 1 to 11 of 11
    May 2004
    Need Help po sa Innova namin
    Pag press ng brake walang light pero pag naka headlight meron siya. Replaced the bulb ganun pa rin... what could be wrong?
    Feb 2009
    Quote Originally Posted by 1997 View Post
    have you checked the fuses? there is a brake light fuse and maybe you mistook the tail lights for brake lights.
    jick
    May 2004
    may idea po ba kayo kung saan yung fuse ng innova? na Check ko po yung sa may engine bay ok naman po lahat ng fuse dun...
    Oct 2008
    sir paki check po yung brake light switch.. nasa taas po ng brake pedal yun. baka sira na po..
    jick
    +1. But if you did not mistake the taillight as the brake light, possible rin na loose grounding wire. Was there any electrical work done on your Innova recently?
    Feb 2009
    if innova is a toyota on a hilux platform, check the left kick panel or around the dashboard on the driver side
    jick
    baka naman po yung pinalit nyo na ilaw ay hindi brake lights
    dapat po kasi yung double contact ng bumbilya ang ipapalit para sa brake light
    Pa Check rin iyong brake light switch.
    Aug 2006
    Quote Originally Posted by loverboy_0901 View Post
    +1 Double contact bulb for brake light.
    Oct 2009
    +1 baya yan lang ang problema po.
    First is pundido ba yung both sides na brake light before?
    If you replaced the bulb with double contact naka align ba yung 3 contacts, one is ground, 2nd is parklight 3rd is brake. Try rotating the bulb 180 degrees and fasten it.
Innova Brake Lights
