Results 11 to 20 of 22
- Jul 2010
- 570
September 16th, 2013 02:24 PM #11Nalaman mo kung ano reason nasira yun spark plug. Baka kasi umulit uli pag sira ng spark plug. May oil ba yun gap ng spark plug. Dyan kasi nasisira ang spark plug kapag sobra dami ng sunog na oil o carbon deposits sa gap. Lumulundag kaagad yun spark voltage sa carbon deposits. So konti lang bigay nito na spark..
- Sep 2013
- 5
September 17th, 2013 10:53 AM #12
Napacheck ko na dinala ko sa kilalang talyer dito sa tsikot, initial findings SENSOR daw pero sad to say hindi yun ang problema kase nung nagpalit ng sensor ganun pa rin tumatalon at huminto kotse ko. 2nd findings TRANSMISSIONS - sumaket ulo ko talaga! so what i did pinullout ko car at hanap ng second opinion ng ibang mekaniko. In god's help yung tatlong mekaniko na nag-check iisa lang sinabi IGNITION COIL problema. So ngayon okay na at tumakbo na ng mahusay.
- Jul 2010
- 570
September 17th, 2013 03:14 PM #13Buti na lang IGNITION COIL lang.
Dapat talaga marunong mag isolate ng trouble para di magastos. Gaya nun sensor daw. Sana sinubukan niya tangalin muna connector ng sensor. Kung nagluko lalo engine ay ok pa sensor mo. or magkaroon ng error code.
Itago mo na lang yun SENSOR na napalitan. Buti di ka nagpalit ng Transmission. He he he.
September 17th, 2013 03:19 PM #14
- Sep 2013
- 5
September 19th, 2013 12:47 PM #15
- Sep 2013
- 5
September 19th, 2013 12:59 PM #16
September 20th, 2013 12:22 PM #17
ganitong ganito din problema ng ae92 ko, pero pinatingnan ko na sa mekaniko ok naman daw ignition coil, i think its time to get a second opinion...
- Jul 2009
- 153
November 18th, 2013 04:30 PM #18Malas! My GF was on EDSA just this morning on her way to Villamor Airbase to donate clothes tsaka to volunteer in relief operations for Samar victims when all of a sudden huminto na naman yung makina. Ayun, "KABLAG!!" Nabundol sya sa likuran ng isang Toyota Vios na Military vehicle! Buwisit! Wasak auto ko, di ko pa din alam kung ano problema nya sa makina!
November 18th, 2013 05:22 PM #19
- Jul 2009
- 153
December 17th, 2013 11:46 AM #20Update lang po. Dinala ko sa Honda SPA last Dec. 7. Lumitaw sa laptop/engine analyzer nila "sticky IAC valve", "faulty IAC valve". Estimate nila mga P17thou++ yung cost ng part wala pa labor. Nag try sila ng test part to make sure. This time wala na yung error code ng IAC valve pero ang lumabas naman sa laptop nila ay "faulty ECU". Estimate nila sa ECU (computer box) ay P78thou++.
Hindi naman nalubog sa baha pero nag try ulit sila ng test part ng ECU. Ay hindi pala, sinalpak nila yung ECU ko sa ibang Honda city dun at lumabas na wala naman naging problema yung test vehicle na pinagsalpakan so it means hindi sira ECU ko. Nakahinga ako ng maluwag.
Next they tried to suspect the fuel pump motor dahil nag test sila ng pressure at mahina na daw ang buga. Kutob ko fuel filter barado lang pero they insist na fuel pump motor daw talaga. Estimate nila sa part ay P21thou++. Wow mahal din at mas mahal pa sa IAC valve.
Nag hanap ako sa Banawe dun sa Multi Auto Parts near Security Bank na recommended ng friend ko who owns a large taxi fleet. Umabot din sa P13thou binayaran ko kasi dinamay ko na din yung AT support (worth P3,500) kasi sira (punit na) tsaka bumili na din ako ng air filter (P1,500) for my ford trekker (motorcraft ang brand). Ang sabi ng Honda SPA may surcharge daw sila na 20% of the cost of the part bought outside so dapat dala mo O.R. ng pinagbilhan mo ng piyesa. Palibhasa wala silang kinita sa parts nila pero at least nakatipid pa din ako. Same supplier din naman yung pinagbilhan ko, supplier din ng Honda.
Inaantay ko lang ma-deliver yung part. Balitaan ko kayo ulit.
Dito sa pinas, daming dahilan kung bakit natetengga pero kadalasan niyan gusto lang ng pampadulas....
Makati Subway. Completion date: 2025
