Results 1 to 10 of 193
- Aug 2010
- 86
July 10th, 2013 11:46 AM #1Sirs, ask ko lang. Critical ba yung amp rating ng mga battery booster cables? Sa 2.0Li na engine ano dapat rating?
TIA.
July 11th, 2013 01:21 AM #2
- Aug 2010
- 86
July 11th, 2013 09:54 AM #4
Most commercial jumper cables are 4 American wire gauge size do automotive use and will suffice for a 1.3 liter gas engine
July 11th, 2013 10:42 AM #6
July 11th, 2013 11:01 AM #7
^Thanks.
I had one of those cheap 250 or 300amp ones before. It broke (the clamp in particular) after we tried jumpstarting my neighbor's Beetle. :D
On connecting jumpers:
1. Red (+) on the drained battery
2. Red (+) on the good battery
3. Black (-) on the good battery
4. Black (-) on a chassis/ground point on the car with the drained battery.
This is correct right?Last edited by vinj; July 11th, 2013 at 11:35 AM.
July 11th, 2013 11:22 AM #8
Do note that the larger the engine displacement, the larger the cranking current. Also, Diesel engines, due to the nature of their design (higher compression ratio), will also have higher cranking current requirements compared to a similar-displacement gasoline engine.
July 11th, 2013 11:25 AM #9
July 11th, 2013 11:36 AM #10
Ngayong summer at malakas Ang sikat Ng late afternoon sun, mas visible Ang mga kasalubong Kapag...
Daytime running lamp (DRL)
