Results 1 to 10 of 193
Threaded View
    #28
    Quote Originally Posted by sirkosero View Post
    been planning to do this. question, anong klaseng lead gamit mo? yung nabibili sa deeco na pang electronics or yung ginagamit sa radiator na parang stick?
    you can still use soldering wire with rosin core, but you will have to feed it fast! mebbe if you can source the thicker size..
    or you can use the lead bar they use in radiator shops. but you need to get some rosin to add to the parts you are gonna solder, to make the metals stick well.. kahit sa ace, meron nyan.
    and you can use a small blowtorch, to heat it faster and evener..
    i know this system works, because we have used it before, to solder battery cables to battery clamps.
    good luck.
Jumper cable amp rating
