Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 159
    Mar 2004
    He lives in a condo ... battery charger is not an ideal solution ...
    Apologies, dint backread.[emoji4]
    Feb 2014
    here's the dilemma cold starts cause the most engine wear i.e. that time when you don't get the oil circulating yet AND the engine temperature isn't optimal yet
    idling in the garage generates minimum heat thus it takes a longer time to reach optimal temps
    are you sure you wanna do this engine-wearing procedure every week?
    wouldn't it be better to remove the battery and take it up w/ you in the condo then hook it up to a float charger? then take out the car for a drive every month or so
    Quote Originally Posted by Vodka View Post
    ^This![emoji106]
    Jun 2015
    3 year old thread...
    Sent from my ASUS_T00J using Tapatalk
    Feb 2014
    3yo thread for a topic on a battery technology that's 150 years old
    the battery technology may be 150 years old,
    but the charging technology is more recent.
    Nov 2017
    Mga boss, sana may makasagot po, nalilito na po kasi ako sa iba iba na sinasabi ng mga mekanikong pinagtanungan ko. Tinanggal po ung battery ng honda city 06 (automatic) ko, bago po sya tinanggal wala po akong problem sa sasakyan, very smooth ang takbo. Nung binalik na po ung battery after ng 8hours siguro hindi ko po sya na check agad, after 1 day ko pa sya nagamit at nung ginamit ko po nagkaroon na ng vibration at low speed, may instance na nakatapak ako sa brake then pag release ko hindi sya aandar at may time din na parang nag jejerk sya habang naka full stop or at low speed, dinala ko po sya sa mekaniko at iniscan at nakita na nag nenegative ung idling kaya pinalitan ang spark plugs at ignition coil. ang tanong ko po kung related ba sya sa pagtanggal ng battery kaya nasira? kasi po ok naman sya bago tinanggalan ng battery tapos nung pagbalik ganun na.
    salamat po sa makakasagot.
    Mar 2005
    Could have been avoided by just letting it idle for 20mins after putting back the battery. ECU's need to re-learn your throttle body intake...
    Feb 2014
    Quote Originally Posted by whileimdriving View Post
    read the manual
    there's a section on re-learning the idle speed
    shared by anya from pdvd
    authorized seller ng motolite
    Yung 2013 Amaron ko, one month ko ata hindi na start, umandar pa rin!!! Ideally weekly ko i start
    Jan 2009
    The engine will survive even if you don't run it for a month or even longer. It's the battery you need to look after.
    I've planned to charge mine for 6 hours on low (or until the Ammeter goes down to zero) every Saturday. Better if you have a 24x7 trickle charger for a worry-free, battery charge management. I already started this last weekend, after cleaning the engine bay.
    its not the battery in your case, when your ignition is at the off position, there is probably no load on the battery. no alarm perhaps?
    Trickle charging keeps em healthy. Trusty ol' Deltran.[emoji106]
    Mar 2018
    The Deltran was on my shopping list when I was in Seattle. Kaso panay 110v ang available.
    I just ended buying a Sparco brand locally. Same 1.25 amperes [emoji1362]
    Deltran produces 110v & 220v. Got both. It used to have a Ph distributor way back. Now they're all carrying CTEK here.
    Jan 2009
    With the battery situation taken cared of, what do you guys think of the fuel left in the tank? I think I have more than 3/4 tank of Diesel left from the last full-tank two weeks ago (Petron Diesel Max).
    Diesel, in particular, is prone to "Diesel Bugs". How long do you suppose Diesel fuel in storage would last before bacteria and fungi starts to become a problem? For that matter, how do they maintain the fuel health in Diesel generators which doesn't see much action for months or even years on end?
    Mar 2018
    Oh actually nagpahanap ako sa friend ko sa Amazon. He told me 110v lang meron. I should have double checked [emoji17]
    to those who have no choice,
    220-110 V step-down transformers and such, are cheap and easily sourced.
How often should I start my car to prevent my battery from draining?
