Page 6 of 16 FirstFirst ... 2345678910 ... LastLast
Results 51 to 60 of 159
    #51
    shared by anya from pdvd
    authorized seller ng motolite
    #52
    Yung 2013 Amaron ko, one month ko ata hindi na start, umandar pa rin!!! Ideally weekly ko i start
    Aug 2004
    #53
    Garage queen is hooked up to the CTEK charger. We're using the DD during the lockdown to contain any possible contamination to one vehicle.
    The 2017 Amaron in the DD is still going strong. It went through 2 CTEK reconds already since 2018 and I charge it up about once a month.
    Jan 2009
    #54
    The engine will survive even if you don't run it for a month or even longer. It's the battery you need to look after.
    I've planned to charge mine for 6 hours on low (or until the Ammeter goes down to zero) every Saturday. Better if you have a 24x7 trickle charger for a worry-free, battery charge management. I already started this last weekend, after cleaning the engine bay.
    #55
    Trickle charging keeps em healthy. Trusty ol' Deltran.How often should I start my car to prevent my battery from draining?
    #56
    its not the battery in your case, when your ignition is at the off position, there is probably no load on the battery. no alarm perhaps?
    Mar 2018
    #57
    The Deltran was on my shopping list when I was in Seattle. Kaso panay 110v ang available.
    I just ended buying a Sparco brand locally. Same 1.25 amperes How often should I start my car to prevent my battery from draining?
    #58
    Deltran produces 110v & 220v. Got both. It used to have a Ph distributor way back. Now they're all carrying CTEK here.
    Jan 2009
    #59
    With the battery situation taken cared of, what do you guys think of the fuel left in the tank? I think I have more than 3/4 tank of Diesel left from the last full-tank two weeks ago (Petron Diesel Max).
    Diesel, in particular, is prone to "Diesel Bugs". How long do you suppose Diesel fuel in storage would last before bacteria and fungi starts to become a problem? For that matter, how do they maintain the fuel health in Diesel generators which doesn't see much action for months or even years on end?
    Mar 2018
    #60
    Oh actually nagpahanap ako sa friend ko sa Amazon. He told me 110v lang meron. I should have double checked How often should I start my car to prevent my battery from draining?
