Page 5 of 16 FirstFirst 12345678915 ... LastLast
Results 41 to 50 of 159
    #41
    Quote Originally Posted by Vodka View Post
    here's the dilemma cold starts cause the most engine wear i.e. that time when you don't get the oil circulating yet AND the engine temperature isn't optimal yet
    idling in the garage generates minimum heat thus it takes a longer time to reach optimal temps
    are you sure you wanna do this engine-wearing procedure every week?
    wouldn't it be better to remove the battery and take it up w/ you in the condo then hook it up to a float charger? then take out the car for a drive every month or so
    ^This![emoji106]
    Jun 2015
    #42
    3 year old thread...
    Sent from my ASUS_T00J using Tapatalk
    Feb 2014
    #43
    3yo thread for a topic on a battery technology that's 150 years old
    #44
    the battery technology may be 150 years old,
    but the charging technology is more recent.
    Nov 2017
    #45
    Mga boss, sana may makasagot po, nalilito na po kasi ako sa iba iba na sinasabi ng mga mekanikong pinagtanungan ko. Tinanggal po ung battery ng honda city 06 (automatic) ko, bago po sya tinanggal wala po akong problem sa sasakyan, very smooth ang takbo. Nung binalik na po ung battery after ng 8hours siguro hindi ko po sya na check agad, after 1 day ko pa sya nagamit at nung ginamit ko po nagkaroon na ng vibration at low speed, may instance na nakatapak ako sa brake then pag release ko hindi sya aandar at may time din na parang nag jejerk sya habang naka full stop or at low speed, dinala ko po sya sa mekaniko at iniscan at nakita na nag nenegative ung idling kaya pinalitan ang spark plugs at ignition coil. ang tanong ko po kung related ba sya sa pagtanggal ng battery kaya nasira? kasi po ok naman sya bago tinanggalan ng battery tapos nung pagbalik ganun na.
    salamat po sa makakasagot.
    Mar 2005
    #46
    Could have been avoided by just letting it idle for 20mins after putting back the battery. ECU's need to re-learn your throttle body intake...
    Feb 2014
    #47
    Quote Originally Posted by whileimdriving View Post
    read the manual
    there's a section on re-learning the idle speed
    Mar 2004
    #48
    ... or the mechanics could've simply cannibalized your vehicle for parts ...
    Oct 2003
    #49
    Jerking at idle or low speed? City 06 automatic? CVT issues. Mechanic probably did not do the CVT reset procedure din.
    Feb 2020
    #50
    Quote Originally Posted by crosswind View Post
    once a week a leave it running for 15 minutes
    that's what we do on our seldomly used vehicles
    every 15 days for about 5 min running time provided there are no alternator problems
How often should I start my car to prevent my battery from draining?
