Page 2 of 6 FirstFirst 123456 LastLast
Results 21 to 40 of 159
    Jan 2014
    Ako naka idle for 30-45 mins once a week with reb para circulation ng battery at yung oil kasi 2-3 times a month ko Lang na gamit auto
    Posted via Tsikot Mobile App
    The moment you notice the engine turns sluggishly when you start, you're not doing it often enough.
    But seriuosly, get a cheapo voltmeter at any reputable store and see to it the battery retains 12.5 - 13.2 volts, and maintain it at that level, always
    Aug 2012
    Average battery life is 3 to 5 years depending on driving conditions. Primary enemy of battery is high temperature. Pero basta tapos na battery warranty, dapat lagi ka na naka-monitor. Use voltmeter (multi-tester) to check battery voltage.
    Apr 2013
    Thanks sa replies. Sorry ts kung medyo na hijack ko ang thread mo. Btw, i'm using motolite gold eversince. Siguro nga hindi ko din kasi pinapansin yung manufacturing date ng battery. Sa tires ako talagang partikular pagdating sa manufacturing date. Thanks again. Btw, iyung amaron ba mas mahaba ang bigay na warranty kumpara sa motolite?
    my suggestion...
    price of battery, divide by number of months warranty, equals cost per month.
    then you'll see just how expensive some batteries are..
    Aug 2012
    ^check out the Amaron battery thread.
    http://tsikot.com/forums/electricals...battery-87052/
    Mar 2005
    Gamit ko Deltran Battery Tender with OBD Port Cable para sa 3 cars namin na sobrang bihira magamit. Much cheaper in the long run instead of running the engine to charge the battery.
    Quote Originally Posted by jmpet626 View Post
    how much po?
    Feb 2009
    If your concern is battery getting discharged for inactivity of the car, purchase a solar battery trickle charger of at least 1 ampere of charging capacity connected to your battery.
    Posted through phlpost.gov.ph
    Feb 2009
    Aug 2012
    If battery is healthy, you can leave the car untouched for 2 months and battery will still have enough charge to start the engine.
    Driving the car on weekends (30-60 minutes) is enough to charge the battery. Higher RPM will charge the battery faster. Highway driving is ideal. City driving with stop-and-go traffic will take longer.
    Idling wastes too much fuel for too little battery charge that you're better off not starting the engine. Note that by starting the engine, you are draining battery power again.
    Alternator produces little power during idle (low RPM). It will power up the car computer, sensors, fuel pump, spark plugs first. Only excess power goes to charging the battery.
    If car will be unused for extended period of time, a battery tender/maintainer or smart/automatic battery charger would be very useful. Easy to use, it will keep your battery at full charge until your next drive.
    http://tsikot.com/forums/electricals...charger-98688/
    Feb 2009
    Nov 2017
    Car batteries drain over a period of time. While it should be fine over a month, the key is to make sure it is charged enough to offset the drain. Some install trickle chargers but that might not be possible in a condo. As long as you take it on a reasonable drive every other week to top it up, it should be ok. If not, then you will need to install a battery isolator to save you from having to repeatedly remove and reinstall the line leading to the battery terminal.
    Quote Originally Posted by muddatrucker View Post
    I recently moved to a condo that's walking distance from my office so I hardly use my car anymore except on weekends. I was wondering, is once a week enough to prevent my battery from being drained or should I start/drive it around more often?
    I have a 2008 Ford Focus (diesel) if that makes a difference.
    if you trust your car caretaker, have him drive the car out every week, for at least 30 minutes. kung short time drive lang, baka mas marami pang kuryente to start her than less than 30 minutes' worth of alternator charging.
    or you can ask caretaker to put battery charger to work.
    otherwise, it might be better to allow the battery to go flat. new battery is cheaper than pukpok, masilya and paint.
    I start it once a week but sometimes I forget for up to 3 weeks and still fine. Amaron is the best
    Oct 2009
    pag ba ung batt kahit bago pero madalang gamitin ung sasakyan aabutin din ba ng 2 years.ex,once a month lang ma istart ng mga 30 minutes ng nasa garahe.diba dapat ma drain lang siya kung hindi gamitin. at pwede naman ipa charge..
    kasi ung sa kumpare ko ford focus wala pang 2 years patay na ung battery seaman kasi siya kaya naka tengga lang ung sasakyan sa garahe .ganun ba talaga ung focus
    Quote Originally Posted by jaypee10 View Post
    batteries deteriorate faster, if they are left in low-charge condition for long periods of time.
    batteries last longer if they are fully charged all the time.
    starting the car is a big drain on the battery. it should be followed by a long-enough drive, to regain that electricity, and even longer, to top up the battery.
    if one can't do that, then a battery charger is in order.
    simply idling the engine may not be adequate charging.
    no need to idle.. it poisons and pollutes our metro manila air
    Severe air pollution: Like London in a bygone age, Delhi has turned into the city of nightmares
    Dec 2009
    A voltmeter in the car lighter socket will reduce your worry about battery drain to non sense
    If you will not use your car for a long period of time you should worry more about your car aircon. Aircon compressor lubricants can solidify enough to get that compressor stuck.
    To prevent that from happening start your car and operate your aircon for 5 minutes every week
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Grab a Deltran or CTEK batt tender. Either can be pluggled 24/7. They trickle charge, auto-off when full. The single ports are about Php5k. These keep the batt healthy longer...& keep electrical gremlins at bay (esp the euro divas). Tenders pay for themselves, a 1 time investment. Those 2 brands are very durable, too. For Start/Stop cars, use the CTEK CT5 Start/Stop.
    Frequent cold starts & idling can't be good. Cars are best driven & enjoyed as often possible.[emoji4]
How often should I start my car to prevent my battery from draining?
