Results 31 to 40 of 159
- 52,731
November 14th, 2017 08:02 PM #31if you trust your car caretaker, have him drive the car out every week, for at least 30 minutes. kung short time drive lang, baka mas marami pang kuryente to start her than less than 30 minutes' worth of alternator charging.
or you can ask caretaker to put battery charger to work.
otherwise, it might be better to allow the battery to go flat. new battery is cheaper than pukpok, masilya and paint.
heh heh.Last edited by dr. d; November 14th, 2017 at 08:05 PM.
November 14th, 2017 08:05 PM #32
I start it once a week but sometimes I forget for up to 3 weeks and still fine. Amaron is the best
- Oct 2009
- 2,271
November 14th, 2017 08:09 PM #33pag ba ung batt kahit bago pero madalang gamitin ung sasakyan aabutin din ba ng 2 years.ex,once a month lang ma istart ng mga 30 minutes ng nasa garahe.diba dapat ma drain lang siya kung hindi gamitin. at pwede naman ipa charge..
kasi ung sa kumpare ko ford focus wala pang 2 years patay na ung battery seaman kasi siya kaya naka tengga lang ung sasakyan sa garahe .ganun ba talaga ung focus
- 52,731
November 14th, 2017 08:16 PM #34batteries deteriorate faster, if they are left in low-charge condition for long periods of time.
batteries last longer if they are fully charged all the time.
starting the car is a big drain on the battery. it should be followed by a long-enough drive, to regain that electricity, and even longer, to top up the battery.
if one can't do that, then a battery charger is in order.
simply idling the engine may not be adequate charging.Last edited by dr. d; November 14th, 2017 at 08:20 PM.
November 14th, 2017 08:18 PM #35
no need to idle.. it poisons and pollutes our metro manila air
Severe air pollution: Like London in a bygone age, Delhi has turned into the city of nightmares
November 14th, 2017 11:50 PM #36
A voltmeter in the car lighter socket will reduce your worry about battery drain to non sense
If you will not use your car for a long period of time you should worry more about your car aircon. Aircon compressor lubricants can solidify enough to get that compressor stuck.
To prevent that from happening start your car and operate your aircon for 5 minutes every week
Sent from my GT-P3110 using Tsikot Forums mobile app
November 15th, 2017 08:09 AM #37
Grab a Deltran or CTEK batt tender. Either can be pluggled 24/7. They trickle charge, auto-off when full. The single ports are about Php5k. These keep the batt healthy longer...& keep electrical gremlins at bay (esp the euro divas). Tenders pay for themselves, a 1 time investment. Those 2 brands are very durable, too. For Start/Stop cars, use the CTEK CT5 Start/Stop.
Frequent cold starts & idling can't be good. Cars are best driven & enjoyed as often possible.[emoji4]
November 15th, 2017 03:51 PM #38
He lives in a condo ... battery charger is not an ideal solution ...
November 15th, 2017 03:56 PM #39
- Feb 2014
- 2,536
November 15th, 2017 05:01 PM #40here's the dilemma cold starts cause the most engine wear i.e. that time when you don't get the oil circulating yet AND the engine temperature isn't optimal yet
idling in the garage generates minimum heat thus it takes a longer time to reach optimal temps
are you sure you wanna do this engine-wearing procedure every week?
wouldn't it be better to remove the battery and take it up w/ you in the condo then hook it up to a float charger? then take out the car for a drive every month or so
Xiaomi E-Car
