Results 1 to 7 of 7
Threaded View
- 54,207
May 20th, 2014 03:07 PM #4as jick says, puede kung puede. but it really depends on the partricular part. if it is a weight-bearing part or pressure part or friction part, i suggest complete replacement, because chances are it will break again...
but you will have to remove the assembly and see if it is worth glueing.
but if the part is next-to-impossible to source or is very expensive (memories, memories..), then glueing may be your only recourse..
good luck.
btw, sometimes, epoxy is the better glue material, because it offers "body" or bulk, that cyanoacrylate can not give.
I got it from lazada. I've seen only 3 pounders at mall hardware stores kaya pinatos ko na ito...
Fire Extinguisher for Car: what brand and type...
