Results 1 to 10 of 19
- Apr 2012
- 26
April 21st, 2014 06:51 PM #1Hi Bros,
Patulong naman, yung auto is 2005 vios 1.5 G matic.
Lately, na-experience ko na after gamitin yung auto it takes 2 tries before sya mag start. Example halimbawa nag-mall kami ng family ko, pagbalik namin sa parking after 3-4 hours di na sya 1-click pag start. It never happened before naman and bago lang ang battery.
Pero pag first use mo naman like sa morning 1-click lang. Ano kaya ang possible problem?
Thanks
April 21st, 2014 06:53 PM #2
^^^fuel filter. Or pwede mo unahin cleaning ng throttle body, servo or iacv ang tawag dun. Visit vios thread and may step by step dun nanpwedeng I-diy
Posted via Tsikot Mobile App
April 22nd, 2014 10:40 AM #3
- Apr 2012
- 26
April 22nd, 2014 12:10 PM #4Thanks bros. Hindi ako sanay mag-DIY eh. Do you have any ideas how much the service will cost sa Servitek? I already have fuel filter which I bought last year pero di ko pa napalagay.
Thanks
April 22nd, 2014 12:43 PM #5
Sor imho, sensitive fuel filter ng vios at mukhang yun nga problema mo king hindi mo pa napapalitan. Unahin mo na iyun at pede dalhin sa suking servitek. May natatandaan din ako na minsan sablay ang replacement kaya better go with oem.
Hrh
April 22nd, 2014 11:40 PM #6
since ang problema mo ay after hot soak may posibilidad na vapor lock ang problema.
- Jul 2010
- 570
May 15th, 2014 05:40 PM #7Kung walang redondo ay pa general cleaning mo na yun commutator ng alternator. Baka pudpod na rin carbon brush niya. Gastos kja lang ng P350 sa labor niyan sa auto electrical.
Pero unahin mo muna yun pinaka simple. Check kung maluwag yun bolt sa mga malaking gauge wire sa battery terminals.Last edited by Chinoi; May 15th, 2014 at 05:43 PM.
May 15th, 2014 06:25 PM #8
Had the same problem with my 2002 Nissan Exalta. Hard starting after use. Problem was the starter solenoid. Replaced it and the problem disappeared. You might also want to check that out.
- May 2014
- 2
May 18th, 2014 09:50 PM #9also with my car, same problem but faulty alternator they replace another one ayun one click agad start na!
- May 2013
- 11
August 8th, 2014 11:56 PM #10Follow up question lang po sana rito sa thread. I'm experiencing the same problem with my 1998 Honda City. Madaling mag-start sa umaga then after going to church or mall 2-4 clicks bago mag-start ulit. Nagcra-crank lang pero di tumutuloy sa pag-start until the 3rd or 4th try. Ang catch lang pag nag-start na, hindi siya agad maka-rebolusyon. Kahit tapakan yung gas pedal, di nagrerebolusyon yung engine. Yung tunog nung engine parang mag-o-off siya hanggang sa eventually mag-off nga siya. Susubukan ko ulit i-start tapos ganun ulit tunog nung engine hanggang eventually kakatapak ko ng gas pedal e magrerebolusyon na rin siya.
Kakapalit ko lang ng battery nung Feb tapos as of Feb this year ok pa naman daw ang alternator. Ano po kaya ang pwedeng sira at magkano kaya aabutin ang pagpapaayos?
Thank you in advance!
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
