Results 11 to 19 of 19
- Jul 2011
- 1,711
August 9th, 2014 09:50 AM #11similar tayo sa problem, ang ginawa ko either shell racing or blaze muna ang ginamit ko, nag improve hanga nawala ung problem ko, nung nagstable na ako sa starting bumalik na ako sa fuel save.
observe mo din kung saan ka nag papagas, as much as posible stick to one gas station para maalagaan ang fuel na pumapasok sa car mo.
- Mar 2014
- 901
August 9th, 2014 04:43 PM #12Pgm-EFI po ba model nung sa inyo?
Kapag Pgm-EFI po ang model, auto choke yan sa first start po.
- Mar 2014
- 901
August 9th, 2014 04:58 PM #13Base po sa nasabi nyo problema, marami po pwede paghanapan kung saan at ano ang nagdudulot ng problema.
Na-checked nyo na po ba ang fuel filter nyo? Kung hindi pa ito napalitan after a year or two have it replace. Check nyo rin po ang air filter nyo, kapag marumi, have it cleaned by air compressor in any service station.
August 9th, 2014 06:15 PM #14
nothing personal but state your facts and questions in order and logically.
does the engine crank?
yes or no
if it cranks, does it crank normally
yes or no
if it cranks, does it start?
yes or no
if it starts, does it take a couple of tries before it finally start?
yes or no
it will take too many guesses just like a guessing game
August 9th, 2014 07:13 PM #15
- May 2013
- 11
August 9th, 2014 10:15 PM #16Thanks for the suggestions! I'll have my air filter and fuel filter checked first.
- May 2013
- 11
August 9th, 2014 10:25 PM #17does the engine crank?
yes
if it cranks, does it crank normally?
I don't how a normal and a not normal crank sound. Basta it cranks but does not start.
At first try, it won't start. But at the 3rd or 4th try it cranks then starts pero parang pumupugak-pugak yung sound ng engine and hindi siya nagre-rev kahit tapakan ko gas pedal and then eventually mamamatay yung engine on its own.
Yes, after mga 4-5 times of trying, eventually, magrerev din yung engine.
August 10th, 2014 05:41 AM #18
Check your fuel for contamination. Check your spark intensity. The spark plugs will tell you a story. If you are unable to read the plugs, mark the position which cylinder they came from and take pictures for posting
Posted through phlpost.gov.ph
- May 2013
- 11
August 10th, 2014 10:31 PM #19Thanks jick.cejoco! Will take note of all your recos when I have it fixed next weekend.
Thanks again guys!
Or none of the above? We've had Ferraris and Lambos burn in SLEX and NLEX in the Philippines...
Hybrids and EV
