Originally Posted by
dr. d
try to inspect the fusebox first. it might be just busted fuse.. consult the car manual..
if you are a little car-savvy, you can check the headlight bulb. the low beam filament might be busted. sometimes, you do not even need testing instrument. simply looking into the filament will show you...
as to the wiper, sometimes the wiper motor is ok. but the wiper mechanism disconnected. if you can hear or detect the wiper motor working, then it must be disconnected wiper lever. (now, that! ... is not an easy repair job to do..)
good luck.
