Page 10 of 13 FirstFirst ... 678910111213 LastLast
Results 181 to 200 of 241
    Jul 2010
    #181
    *Teamnitro
    Ganda talaga ng gawa mo. Ingit talaga ako.
    Pero gagayahin ko iyan.
    *isa1023
    Ramdam na ramdam na ngayon pagkakaiba. Hindi na nagfflicker lights ko.
    Congrats. Feeling parang bagong battery kotse mo.
    #182
    [QUOTE=Chinoi;1558571]*Teamnitro
    thanks bro gawin mo na din...
    Jan 2008
    #183
    What I know is that computerized vehicles are already installed with multiple ground connections.
    Yung old van ko di lang multiple grounds ang nilagay. I also installed that huge battery relay (from battery to fuse box with 8G auto wire). The relay is activated by ignition swiitch.
    So my fuse box has two power lines:
    1. From ignition switch
    2. From battery via the relay.
    I made it because my fuses were melting and my ignition switch becomes hot when I turn-on the AC. I also replaced the fuse box with heavy duty surplus which luckily has heavy duty fuses installed (HD fuse is expensive more than P75.00 ea).
    We retained the old connection to the ignition switch as a security in case the battery relay breaks down.
    Jul 2010
    #184
    sa mga nag DIY po ng grounding kit nila, saan po kayo nakabili nung parang brass plate na kinakabit sa negative terminal ng battery? Yung pinaka central tapping point ng lahat ng wires? Nakabili na po kasi ako nung ibang materials except for that. help pls!
    #185
    im also looking for that part yung brass plate central tapping location connected sa negative terminals of the battery. I've seen this sa banawe kaya lang bundled sya sa kasama yung mga grounding wires, kaya lang meron na din ako DIY na wires...
    Saan ba makakabili nito or magpapafabricate nalang ba ako?
    Apr 2009
    #186
    Quote Originally Posted by Chinoi View Post
    *isa1023
    Thanks paps. Sa wakas nakaramdam ako ng gain from modifications.
    Parang bitin nga eh, mag-DIY nalang ako to tap from distributor to head to chassis naman.
    Jul 2010
    #187
    Quote Originally Posted by GundamWing View Post
    I've seen pics of some really nice central terminals. Hindi ko lang malaman kung saan nabibili. Alam ko sir as long as brass, kung hindi ka naman after aesthetics, pwede na yun ipa-fabricate.
    Apr 2009
    #188
    Pwede naman sir dalawang grounding wire lang naka-parallel sa terminal misom then series nalang from those two grouding wires.
    Jul 2010
    #189
    Quote Originally Posted by isa1023 View Post
    hindi ko po masyadong ma picture to. So sa battery terminal, magkakabit ako ng 2 grounding wires? tapos dun ko ikakabit yung iba pang mga wires sa dalawang naka parallel?
    Apr 2009
    #190
    Quote Originally Posted by kenn.garcia View Post
    000000
    Aug 2010
    #191
    Mga boss nakabili na kasi ako Grounding kit ang problema diko alam paano ang safety ng pagkabit.. dapat bang tangalin ko muna yung negative terminal sa battery bago ko ilagay o iduktong yung terminal ng GK?
    Apr 2009
    #192
    Ok lang siguro kahit hindi na.
    Ingat lang sa pag-tap sa alternator. Sa bracket mo nalang ilagay.
    Aug 2010
    #193
    Hmm tatangalin ko na lang muna para safety lang.. uhhm Kahit negative terminal lang naman tangalin ko noh kahit wag na positive?
    Jul 2010
    #194
    Quote Originally Posted by callantajian View Post
    mga sir, effective po ba kung maglalagay ako ng grounding kit sa altis ko, kahit brand new pa 1 month pa lang? may magbabago kaya? i mean, ung mga ilaw ko, stereo, takbo, etc, magbabago ba? salamat!
    NO no NO no!!!!
    Aug 2005
    #195
    ^^^ mas luma ang sasakyan, mas possible na makatulong ang grounding kit.
    Jul 2010
    #196
    Quote Originally Posted by gr3nd3l View Post
    Positive terminal tangalin mo para sigurado.
    Jul 2010
    #197
    Maganda pa mga ground connection niyan. Hwag muna. Sayang din warranty ng kotse baka ma-void.
    Jun 2010
    #198
    San po maganda mag palagay grounding kits? masmakapal po ba ang wire mas maganda kasi tingin ko need ng nissan vanette 1996 ko ng grounding kit bumababa ang voltage and sobrang likot ng voltage..
    taga Laspiņas City po ako
    Nov 2006
    #199
    [/IMG][/IMG][/IMG][/IMG][/IMG]
    my ground kit DIY. clean and neat no wires exposed...battery negative to alternator, starter, TB, AT solenoid, body, cylinder head...
    #200
    Quote Originally Posted by aijie28 View Post
    Gauge 8 na wire okay na hindi naman kailangan sobrang kapal mahalaga lang maganda ang contact nito at walang kalawang pagkakabitan.
grounding kits
