Page 7 of 13 FirstFirst ... 34567891011 ... LastLast
Results 121 to 140 of 241
    Feb 2010
    #121
    Will try to go to sir denis of CONVOY MODE.... parang mali ata yung nakapost i believe it should be near tyhe boundery of CAINTA and ANTIPOLO sumulong highway.... will give a feed back pag natuloy ako.....my car is an 05 city matic
    Jun 2010
    #122
    Quote Originally Posted by OldSchoolHack View Post
    Yup. Lalo na pag maraming load sa kuryente (like added amps, sub woofers, alarm systems, powerful head unit, powerful headlights). Kahit diesel ok ang grounding kit. Pero kung bago ang sasakyan at stock pa, di needed.
    for a new car, hindi noticeable ang difference. pero tumaas ang reading nang voltmeter ko nang .6 compared sa walang grounding kits.
    Dec 2008
    #123
    Mga Sir asked ko lang if magkakabit ako ng grounding kit sa alternator which SPECIFIC part po ng alternator???? Thanks.
    #124
    Quote Originally Posted by Tatchest View Post
    positive ng alternator to positive ng battery terminal
    Oct 2009
    #125
    Quote Originally Posted by a3n3as View Post
    mine is negative to negative.. which is which ba?
    Jul 2010
    #126
    Meron po ba kayong alam na mabibilihan at marunong magkabit ng grounding kit around Las Pinas area?
    ^ same question.
    actually there's a tsikot.com accessory shop just outside of our village. any one experienced their service already?
    Jul 2010
    #128
    ^ same question.
    Are you referring to the one near Philam gate? Beside Starmall?
    ^sakto bro. may feedback ka ba dun?
    Jul 2010
    #130
    Ang alam ko it's more of an accessory shop. Mga video and sound setup. Which I believe will require competent electricians. Meron ilang testimonials from other Tsikoteers na ok nga daw dun. Haven't tried it myself though.
    Nov 2006
    #131
    grounding is always negative sir. so negative from battery to negative ground on alternator...
    Jul 2010
    #132
    Hi all,
    May nakita po akong HKS (brand) grounding kit sa Blade for P1,000. Included in the kit are 5 relatively short grounding wires and some nuts and bolts. Aesthetically ok naman siya.
    Reasonably priced na kaya yun mga sirs?
    And how long should each wire be? Kasi yung andun siguro mga 3 to 4 ft lng
    #133
    Quote Originally Posted by kenn.garcia View Post
    Hi all,
    I think its a fake sir. I think asa mga P3500 pataas ang grounding kit ng HKS. When I went to Banawe to inquire for a grounding kit inofferan din ako ng ganiyan na HKS grounding kit for only P800.
    Anyways, tanong ko lang po kung normal ba talaga yung humihina ang reception ng tuner mo kapag ino-on mo na ang HID mo? Sabi kasi sa akin nung pinagbilhan ko ng HID, normal lang daw un, pero I have doubts kasi hindi niya ako inofferan na ayusin man lang yun at sinisisi niya ito sa grounding ng sasakyan ko. If ever, kailangan ko ba ng grounding kit for this? TIA mga gurus!
    Jul 2010
    #134
    Quote Originally Posted by beni23 View Post
    Wow! Ang mahal na grounding kit naman nun sir! Would you know kung anong difference ng orig and fake? Kasi kung not much of a difference at branding lang talaga ang pinag kaiba, as long as ma iimprove nya ang grounding ok na rin siguro ako kahit dun sa fake. Yung 800 petot ba kasama na kabit? Sa Blade kasi plus 350 pa pag pinakabit mo.
    Nagtanong din ako kanina sa auto shop na Tsikot endorser dito sa Philam Las Pinas, 1800 daw ang cost ng grounding kit (Groundzero brand). Tapos 700 yung labor ng pagkabit. Reasonable pricing ba yun mga master?
    Please advise po. TIA!
    Mar 2005
    #135
    mahal naman ng install.. simple lang naman pakabit ng grounding kit. Nagpakabit ako dati 700 yung 5 point grounding kit with install na sa banawe. Since sa LP kayo sir dun sa may likod ng ATC dami shops dun baka mas mura sa quote nyo or atleast libre na labor.
    Jul 2010
    #136
    Quote Originally Posted by jmpet626 View Post
    Oo nga sir. kala ko nga makaka mura ako kasi since Tsikot endorser yun shop, inassume ko na aware sila na madali lang yung pag install. Ayoko lang tagala i-DIY kasi gusto ko maayos talaga ang pagkakagawa. Or baka naman ganun talaga kaganda yung pagkaka install nila na worth 700 petot.
    Any specific shop sir that you can recommend dun sa likod ng ATC? O isang shop lang meron dun?
    Mar 2005
    #137
    Magkakatabi mga shops dun sir so pwede ka din makapag canvass. Di ko pa nakita yung install nila so di ako makaka comment. Basta hindi naman nakakasagabal sa ibang components sa pag install ng grounding kit eh ok na sakin.
    Jul 2010
    #138
    copy that. thanks!
    Aug 2010
    #139
    Meron na bang nagpakabit sa Blade ng HKS grounding kit nila!? Feedback naman po balak ko mag avail hehe
    #140
    Quote Originally Posted by gr3nd3l View Post
    di ata nag tanong na ako sa kanila. im planing to buy 1 sa blade para malagyan ko 18 year old nissan bluebird ko.
grounding kits
