*Teamnitro
Ganda talaga ng gawa mo. Ingit talaga ako.
Pero gagayahin ko iyan.
*isa1023
Congrats. Feeling parang bagong battery kotse mo.Ramdam na ramdam na ngayon pagkakaiba. Hindi na nagfflicker lights ko.![]()
*Teamnitro
*isa1023
[QUOTE=Chinoi;1558571]*Teamnitro
thanks bro gawin mo na din...![]()
What I know is that computerized vehicles are already installed with multiple ground connections.
Yung old van ko di lang multiple grounds ang nilagay. I also installed that huge battery relay (from battery to fuse box with 8G auto wire). The relay is activated by ignition swiitch.
So my fuse box has two power lines:
1. From ignition switch
2. From battery via the relay.
I made it because my fuses were melting and my ignition switch becomes hot when I turn-on the AC. I also replaced the fuse box with heavy duty surplus which luckily has heavy duty fuses installed (HD fuse is expensive more than P75.00 ea).
We retained the old connection to the ignition switch as a security in case the battery relay breaks down.
sa mga nag DIY po ng grounding kit nila, saan po kayo nakabili nung parang brass plate na kinakabit sa negative terminal ng battery? Yung pinaka central tapping point ng lahat ng wires? Nakabili na po kasi ako nung ibang materials except for that. help pls!
im also looking for that part yung brass plate central tapping location connected sa negative terminals of the battery. I've seen this sa banawe kaya lang bundled sya sa kasama yung mga grounding wires, kaya lang meron na din ako DIY na wires...
Saan ba makakabili nito or magpapafabricate nalang ba ako?
Pwede naman sir dalawang grounding wire lang naka-parallel sa terminal misom then series nalang from those two grouding wires.
Mga boss nakabili na kasi ako Grounding kit ang problema diko alam paano ang safety ng pagkabit.. dapat bang tangalin ko muna yung negative terminal sa battery bago ko ilagay o iduktong yung terminal ng GK?
Ok lang siguro kahit hindi na.
Ingat lang sa pag-tap sa alternator. Sa bracket mo nalang ilagay.
Hmm tatangalin ko na lang muna para safety lang.. uhhm Kahit negative terminal lang naman tangalin ko noh kahit wag na positive?
^^^ mas luma ang sasakyan, mas possible na makatulong ang grounding kit.
Originally Posted by callantajian![]()
mga sir, effective po ba kung maglalagay ako ng grounding kit sa altis ko, kahit brand new pa 1 month pa lang? may magbabago kaya? i mean, ung mga ilaw ko, stereo, takbo, etc, magbabago ba? salamat!
Maganda pa mga ground connection niyan. Hwag muna. Sayang din warranty ng kotse baka ma-void.
San po maganda mag palagay grounding kits? masmakapal po ba ang wire mas maganda kasi tingin ko need ng nissan vanette 1996 ko ng grounding kit bumababa ang voltage and sobrang likot ng voltage..
taga Laspiņas City po ako
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
my ground kit DIY. clean and neat no wires exposed...battery negative to alternator, starter, TB, AT solenoid, body, cylinder head...
